Addons/Plugins/...
herr_k.
Re: Addons/Plugins/...
Post by herr_k. »
sorry, found the problem here. http was wrongly set to opera.exe that didnt exist.
it is still working though
JohnFredC wrote:Specifically, sometimes I try to upload a recently saved clipboard file. That rarely works without restarting XnView and "re"viewing the saved file.
this is also true.
cheers
foxyshadis
Post by foxyshadis »
Terribly confused, I'm trying to write support for a new format with the Plugin SDK but it isn't working at all. The Plugin SDK exports the following functions:
gfpGetPluginInfo
gfpLoadPictureInit
gfpLoadPictureGetInfo
gfpLoadPictureGetLine
gfpLoadPictureGetColormap
gfpLoadPictureExit
gfpSavePictureIsSupported
gfpSavePictureInit
gfpSavePicturePutLine
gfpSavePictureExit
Every plugin in the XnView\Plugins folder exports the following:
gffGetFormatInfo
gffGetPluginInfo
I'm pretty sure that's why mine isn't being picked up. Soo... how do you map from one to the other? The old SDK hasn't been updated since 2003, and obviously something changed since then. This is what stopped me a few years back when I first tried, too.
gff* are internal plugin, gfp* functions are good.
Do you have changed the extension (.usr)?
RIOT plugin added
Ben321
Post by Ben321 »
Dead link is dead :(
Fixed
Ben321
Post by Ben321 »
xnview wrote:
Fixed
Thanks.
Also, I'm curious about something. If I wish to use xsusie with the GFL SDK, is it possible to use xsusie with the ActiveX version of the GFL SDK? Or does xsusie require the standard dll version of the GFL SDK to work?
Ben321 wrote:Also, I'm curious about something. If I wish to use xsusie with the GFL SDK, is it possible to use xsusie with the ActiveX version of the GFL SDK? Or does xsusie require the standard dll version of the GFL SDK to work?
No, works only with XnView/NConvert
Nikolay Raspopov
Post by Nikolay Raspopov »
What about 64-bit versions of plugins?
Nikolay Raspopov wrote:What about 64-bit versions of plugins?
Some of the plugin exist already as 64bits, you can find them in XnViewMP 64bits version
Nikolay Raspopov
Are they GFL 3.40 64-bit compatible?
Nikolay Raspopov wrote:Are they GFL 3.40 64-bit compatible?
yes i think (not tested)
Solovei95
Post by Solovei95 »
The plugin displays a JNG image with white background. Please fix it.
shrabanti
Post by shrabanti »
I am also getting White Background here too. Waiting for the fix mate. Thanks.
matu
Post by matu »
hello
Can the color of the guide displayed at the time of trimming be changed?
