- NirSoft: WinFontsView
WinFontsView is a small utility that enumerates all fonts installed on your system, and displays them in one simple table. For each font, WinFontsView draws 5 samples of the font in different sizes, in order to allow you to easily find and choose the desired font that you need. WinFontsView also allows you to view the fonts as Bold, as Italic or with underline, as well as it allows you to export the fonts list into html file.
If you need to find a font in non-English character set, WinFontsView also allows you to choose the right characters set of the fonts and to type the characters displayed in the sample text of each font.
In search of a font viewer
- Forum Librarian
Re: In search of a font viewer
ckv
I have this theory that Nir Sofer is actually an sentient AI on supercomputer inside a bunker somewhere. And I think it is seeking world domination by using its utilities to spread through the internet and ultimately taking it over. I'm sure it can already monitor the whole web, so this is for you Nir Sofer - I'm on to you!
But seriously that guy is a machine. He has makes (and regularly updates) tons of tools, most of which are original and very much usefull.
thibaud
if you need a efficient viewer to preview and organize large collection of uninstalled truetype, opentype, type1 fonts here is one not to be missed:
http://www.apolisoft.com/ffr/index.php.
marsh
An experimental windows port called fontmatrix is available. It uses Qt4.
http://fontmatrix.net/
