First-Start screen
helmut wrote:I think the windows title "Setup" is a bit irritating, because with this dialog you do not setup (=install) XnView on the computer. In the dialog you make the initial settings for some options.
ATM, I have no suggestions for a good window title, so your suggestions are most welcome.
Configuration Wizard” seems to be a commonly used term (e.g. Apache Triplesec First Start Configuration Wizard).
XnTriq wrote:...“Configuration Wizard” seems to be a commonly used term ....
Sounds good to me. Let's see what native speakers suggest...
xnview (Announcement: [url=http://newsgroup.xnview.com/viewtopic.php?p=57653#57653]XnView 1.92.1[/url]) wrote: Changed:
* LIBPNG 1.2.24
* F11 open/close fullscreen even with 2 monitors - http://newsgroup.xnview.com/viewtopic.php?t=14188
* Import WIA use same dialog as 'scan into" - http://newsgroup.xnview.com/viewtopic.php?p=56620
* XnViewShellEx must be in ShellEx subfolder
The shell extension is included in the complete version of the ZIP package (XnView-win-full.zip). When the archive is extracted, XnViewShellExt.dll does not end up in its own sub-directory (XnView\ShellEx\), but in the same folder as xnview.exe. Hence, the user cannot activate the Use XnView Shell Extension option on the configuration screen:
  • Image
* LIBPNG 1.2.24
    Yes, right
    Currently, the window opens up and you don't know which application this window belongs to (XnView is not visible in background, yet).
    So I suggest:
    The window title of the dialog should contain "XnView". E.g. "XnView - Configuration wizard".
    helmut wrote:The window title of the dialog should contain "XnView". E.g. "XnView - Configuration wizard".
    Added/changed in v1.93 beta 2.
    Very good - thank you, Pierre! :-) (And thanks, XnTriq, for telling us).
