I want to convert a bunch of pictures, "worst fit". That means:
I want to have a maximum of 1280 width or 1024 height, but none of the values should be scaled down. So both are minimum parameters.
That means: If a picture is 5000x1024, nothing should happen.
If a picture is 1200x10000, it should be scaled up to 1280xy (y is a bit more than 10000 then)-
I hope you see what I mean. Is that possible?
Batch resize images: Worst fit possible?
Wurstwasser
To clarify, because it's somewhat complicated.
Target is: 1280x1024, but width not <1280 AND height not <1024.
I have 2094x2950 px pictures.
Their width is bigger than their height, so I want to have them at 1280 width.
I use the batch converter. I set width to 1280 and height to 1024. The "follow orientation" flag is off.
- If I choose "fit over", I get 726x1024
- If I uncheck "fit over" I also get 726x1024
But the result I wish should be 1280x1443.
Wurstwasser
Wurstwasser
BTW, if you make changes in resize dialogs, add two simple images, because this tells more than thousand words. Generally people may want something like "fit into (which may leave a border)" and "fit only one side and eventually leave a border on the other"...
Yes, I never need the orientation metadata info, because in some pictures it's there, in others isn't... Just adds confusion for me
- Forum Librarian
Wurstwasser wrote:BTW, if you make changes in resize dialogs, add two simple images, because this tells more than thousand words.
