XnView goes to background after file deletion
Dreamer
Post by Dreamer »
xnview wrote:
ckit wrote:Disabling "Go to next image when deleting current" in Options seems to fix it.
Really????
Not here, but it works sometimes - regardless of that option.
Edit: Now I mean deleting the file/folder in browser - just to be sure.
Dreamer
ckit
Post by ckit »
Really????
Yes but I'm still not happy with this situation and may decide to make Picasa 3 my new default manager as XnView isn't compatible with Vista.
Dreamer wrote: Not here, but it works sometimes - regardless of that option.
Deleting in the browser is fine, I'm talking about deleting in View mode.
Dreamer
Post by Dreamer »
ckit wrote:Deleting in the browser is fine, I'm talking about deleting in View mode.
Strange, for me deleting in both fullscreen modes is fine and deleting in browser is buggy. :?
Edit: OK, so it's really strange, sometimes I can delete 50 images in viewer/fullscreen, no problem, sometimes it's wrong after just 10 images. But in the browser it's quite constant, just few images are fine (usually just 1 or 2).
Dreamer
Ok, i think that i found the problem, Vista has change the behavior of a api function :-(
ckit do you want to test a version?
Dreamer
Post by Dreamer »
Original bug (browser) looks fixed, but there is a new problem.
When I delete pictures very quickly using the keys Delete and arrows, xnview is not responding for about 25 seconds.
Now I have same result also by deleting pictures not so quickly (2-3 pictures in a second) - and only using Delete key, no arrow keys.
To reproduce go to folder with 100-200 pictures, go to last one in thumbnail view and start deleting using Delete key quicky.
XnView 1.95.4, cache disabled, Win Vista 32 bit SP1.
Dreamer
ckit
Post by ckit »
Thanks, Pierre I'll test it soon!
Researching DSLR's at the moment :)
Post by Guest »
Any news?
Anonymous wrote:Any news?
It's fixed in 1.95.4
Post by Guest »
Yes, it now works for me. Didn't work before. Thanks!
Post by Guest »
Great! It works :) I was awaiting this fix a long time. I'm glad to see that it is fixed now. Great job! I love this tool! Big thanks!
Christian
cyxxon
Post by cyxxon »
Great, fixed for me as well now! Top work!
