The "_Default - Frame" template (XnView 1.93.4) for thumb.html declares a strict HTML 4.01 DOCTYPE that is incompatible with its use of the attribute 'target' for the 'A' elements it generates. (Try running a created thumb.html through the W3C validator at <http://validator.w3.org/>.)
What's needed here instead is an HTML 4.01 Transitional DOCTYPE (which allows the 'target' attrib) declaration:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
Web page Create: 'target' attrib needs Transitional DOCTYPE
Re: Web page Create: 'target' attrib needs Transitional DOCT
Thank you for the hint. Could you please send a corrected template to Pierre with a link to this forum topic? Thank you!Jambalaya wrote:The "_Default - Frame" template (XnView 1.93.4) for thumb.html declares a strict HTML 4.01 DOCTYPE that is incompatible with its use of the attribute 'target' for the 'A' elements it generates. (Try running a created thumb.html through the W3C validator at <http://validator.w3.org/>.)
