v0.12 Win32: Cosmetics: Filter control display anomaly
Re: v0.12 Win32: Cosmetics: Filter control display anomaly
You have changed only for classic theme? No font change? or DPI?
JohnFredC
Hi Pierre...
Not sure of your question, but the problem shows with all of the MP styles. I can send screenshots but don't have time today.
Are you layering two controls for the Filter thing? Or is that a special control available in QT? Regardless, it appears to be a composite of two controls.
Perhaps a "standard", editable combo box that collects the entries PLUS a couple of buttons to manage the list, apply/cancel the filter...
Here is a quick and dirty (and ugly) illustration:
+ (Add current value to list of filters)
- (Remove current value from list of filters)
X Disable filter
X Disable filter
John
No i means that windows are not in Xp theme but classic theme...JohnFredC wrote: Not sure of your question, but the problem shows with all of the MP styles. I can send screenshots but don't have time today.
JohnFredC
If you try the Xp Theme?JohnFredC wrote:Ah, yes. I use classic theme.
- Forum Librarian
Default theme, default fonts, default resolution, and no effects.xnview wrote:You have changed only for classic theme? No font change? or DPI?
If you compare the two screen caps, ...
... you'll see that the problem has to do with the Qt style sheet.
Pierre, do you know which selectors are responsible for the search field and the stop button? I can't find it on Trolltech's site
JohnFredC
Hi Pierre...
I switched to the Windows XP theme, but there was no improvement.
(...so I switched back
John
Oh, if you use the default theme, there is no problem???
It's a custom controlPierre, do you know which selectors are responsible for the search field and the stop button? I can't find it on Trolltech's site![]()
- Forum Librarian
I see.xnview wrote:It's a custom control
Correct.xnview wrote:Oh, if you use the default theme, there is no problem???
It doesn't matter which style (Windows/Motif/CDE/Plastique/Cleanlooks) I use.
As soon as I activate the View » Style » Theme option, this UI problem with the search box shows up.
To fix it, I have to remove all text in the DlgEdit window.
Even if just a simple space character (Alt+032) is left behind, our problem persists.
@JohnFredC: Can you confirm this behavior with Windows XP?
JohnFredC
Yes! Confirmed as you describe. Good detecting!
Create a theme, apply it.
Observe display problem.
Clear theme, apply.
Close MP.
Restart MP.
Display issue no longer visible.
Clear theme, apply.
Close MP.
Restart MP.
John
JohnFredC
