I am a total novice at this.
I have added a caption to 3 JPG files, with XNVIEW. If I look at them with XNVIEW, they are all still there.
I am using PHP to try to get at that data, but it is not appearing.
I am looping through a directory, which contains several JPGs including the 3, I have added a 'Caption' to. Only one gives me an APP13 entry and that appears to have come from a Photoshop edit sometime in the past.
I am using the following code.
function getIPTC_Data( $file ) {
$size = getimagesize ( $file, &$info);
var_dump($info);
echo BN;
if(is_array($info)) {
$iptc = iptcparse($info["APP13"]);
foreach (array_keys($iptc) as $s) {
$c = count ($iptc[$s]);
for ($i=0; $i <$c; $i++)
echo $s.' = '.$iptc[$s][$i].'<br>';
Any help or guidance, would be gratefully appreciated.
Richard
Newbie: IPTC APP13
