Converting using .xbs file
mfeske
Post by mfeske »
Hello everybody,
i have make xbs files with xnview.
Can I use this 123.xbs to convert with nconvert?
What must I write to convert all pictures in d:\test ?
What must I write to convert all pictures in d:\test an all other folders under d:\test?
Greetings
Micha
Re: nconvert batch
mfeske wrote:Can I use this 123.xbs to convert with nconvert?
Use xnview to load your script and export it as batch script for nconvert
nconvert ... d:\test\*.*
Currently not possible directly with nconvert, but you can with a script
mfeske
Re: nconvert batch
Post by mfeske »
thanks for your answer.
I haven´t found the export to batch script, where must I search.?
Where can I found a script to works with nconvert an all folder under d:\test ?
Greetings
Re: nconvert batch
mfeske wrote: I haven´t found the export to batch script, where must I search.?
Batch convert/EXport
mfeske
Re: nconvert batch
Post by mfeske »
Hello Pierre,
thanks for your fast answer. Now I found this Option.
Is this only for the files in the folder where the batch file is inside?
Where can I change this?
What must I do, that it works with folder deeper this one?
Where is my mistake?
I will convert all jpg from f:\vetmed_converter\picture\incoming\ to f:\vetmed_converter\picture\outgoing\ with prefix de and suffix m , but the batch file isn´t work, it shows only the nconvert freeware information.
nconvert.exe -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o f:\vetmed_converter\picture\outgoing\de_%_m.jpg -dpi -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "F:\vetmed_converter\logo\in_use\de_logo_fu_m.tif" -wmflag bottom-right
Greetings.
Michael
Re: nconvert batch
mfeske wrote:Is this only for the files in the folder where the bacth file is inside?
add at the end, the list of files. nconvert ..... source/*.jpg
mfeske
Re: nconvert batch
Post by mfeske »
sorry haven´t see your post and i have edit my post.
mfeske
Re: nconvert batch
Post by mfeske »
sory, i think i ám so stupid :-(
nconvert.exe -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o f:\vetmed_converter\picture\outgoing\de_%_m.jpg -dpi -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "F:\vetmed_converter\logo\in_use\de_logo_fu_m.tif" -wmflag bottom-right source/*.jpg
isn´t working
in F:\vetmed_converter\logo\in_use\ is my logo file de_logo_fu_m.tif
in F:\vetmed_converter\picture\incoming is my source file for example P1020279.jpg and this time my batch and nconvert to
in f:\vetmed_converter\picture\outgoing\ i will have my target files with prefix de and suffix m
Re: nconvert batch
So it's
nconvert.exe -out jpeg -o f:\vetmed_converter\picture\outgoing\de_%_m.jpg -dpi -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "F:\vetmed_converter\logo\in_use\de_logo_fu_m.tif" -wmflag bottom-right F:\vetmed_converter\picture\incoming\*.jpg
mfeske
Re: nconvert batch
Post by mfeske »
xnview wrote:So it's
Hello Pierre,
sorry but it isn´t working on my computer. Allt times nconvert shows the information screen but isn´t work.
Can I send you testfiles ?
Can this de_%_m.jpg be the Problem?
I have test it with %% than it´s okay, but the konvertierung is not okay. I will resize this picture
to one with and hight automatically. when I use the script in xnview its okay
when i export it to batch isn´t okay :-(
Size not correct, Watermark not correct position must be -5,-5, Watermark alpha not correct must be 70 :-(
My batchline now is:
nconvert.exe -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -o G:\vetmed_converter\picture\outgoing\de_%%_m.jpg -dpi -ratio -rtype lanczos -rflag orient -resize 500 0 -wmfile "G:\vetmed_converter\logo\in_use\picture\de_logo_fu_m.tif" -wmflag bottom-right -wmopacity 70 "G:\vetmed_converter\picture\incoming\P1020279.JPG" G:\vetmed_converter\picture\incoming\*.jpg
pause
exit
Please can anybody help me?
Greetings
Michael
Re: nconvert batch
mfeske wrote: Can I send you testfiles ?
Yes, and the xbs too please
mfeske
Re: nconvert batch
Post by mfeske »
Hello Pierre,
where can I send it ?
Greetings Michael
Re: nconvert batch
mfeske wrote: where can I send it ?
contact at xnview dot com
mfeske
Re: Converting using .xbs file
Post by mfeske »
you haven´t receive it?
mfeske wrote:you haven´t receive it?
Oups, sorry i have it :-)
