how to insert "Creation date" as a text in an picture
poudou99
Post by poudou99 »
Hello
I continue my previous messages here in english
I am trying to insert the "Creation Date" of a list of pictures inside the pictures as a text
After having made several tries (seeing how xnview does with conversion/Batch)
here is what I am trying to do:
SET PRG="E:\Program Files\XnView\NConvert"
SET SRC="IN-##.jpg"
SET DST="OUT-##.jpg"
%PRG% -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -n 0 23 1 -text "<Creation Date [d/m/Y H:M]>" -o %DST% %SRC%
But it does not run, it inserts the text "<Creation Date [d/m/Y H:M]>" itselft instead of the date like XnView does
I certainly make mistakes. But, I do not know what parameter(s) I can use to do the same thing like xnview does
Thanks
Re: how to insert "Creation date" as a text in an picture
poudou99 wrote: But it does not run, it inserts the text "<Creation Date [d/m/Y H:M]>" itselft instead of the date like XnView does
Currently nconvert doesn't support <...> info like xnview
poudou99
Post by poudou99 »
Ok, thanks
I will try something else
I will try to develop a BAT which retrieves the DATE/TIME of the file and then insert it as a text in the picture using Nconvert
poudou99 wrote:I will try to develop a BAT which retrieves the DATE/TIME of the file and then insert it as a text in the picture using Nconvert
With a batch file this might be possible. There's ways to extract parts for the date and string them together, an example which uses the currrent date:
set CREATION_DATE=%DATE:~6,4%-%DATE:~3,2%-%DATE:~0,2%
poudou99
Post by poudou99 »
helmut wrote:With a batch file this might be possible. There's ways to extract parts for the date and string them together, an example which uses the currrent date:
I did something like that
thanks
