[FIXED] RC1: Slideshow-Bug (when Titlebar enabled)
Locked
Lasse
Post by Lasse »
Hi Pierre!
When you chose a folder for a slideshow and enable in the Settings-Section the Title-Bar, the first Image that is shown has a position "out of the window". The second picture and all others will be shown correctly.
Only the first one is wrong. When you enable "no title bar", than it's correct, however ...
Regards,
Lasse
Re: RC1: Slideshow-Bug (when Titlebar enabled)
Lasse wrote:When you chose a folder for a slideshow and enable in the Settings-Section the Title-Bar, the first Image that is shown has a position "out of the window". ...
I confirm this. :bugconfirmed:
Lasse wrote:When you chose a folder for a slideshow and enable in the Settings-Section the Title-Bar, the first Image that is shown has a position "out of the window". The second picture and all others will be shown correctly.
I can't reproduce it, which other flags do you have?
xnview wrote:...
Deactivating the checkbox "No Title bar" in category "Slide show" of options should be sufficient. The problem can be seen in both the normal slide show and the slide show for a specific directory.
helmut wrote:
xnview wrote:...
Ok, now i have it, you must use fullscreen too ;-)
Olive
Post by Olive »
Fixed in RC2. Please move to Solved.
Dreamer
Post by Dreamer »
Olive wrote:Fixed in RC2. Please move to Solved.
OK
Locked
