Error EXIF Data in Nikon
madiazg
Post by madiazg »
I am using version 3.15 of GFL SDK. If I Load an image and saving it, EXIF data are saved correctly:
    gflLibraryInit();
    gflGetDefaultLoadParams(mLoadOption);
    mLoadOption.Flags := GFL_LOAD_READ_ALL_COMMENT;
    mLoadOption.Flags := GFL_LOAD_METADATA;
    mError := gflLoadBitmap(Pchar(FileName1),mOriBitmap, mLoadOption, lInformation); // Carga una imagen en Memoria
    gflGetDefaultSaveParams(mSaveOption);
    mSaveOption.Flags := GFL_SAVE_REPLACE_EXTENSION;
    mSaveOption.Flags := GFL_SAVE_ICC_PROFILE;
    mSaveOption.FormatIndex := 0;
    mSaveOption.Quality := 50;
    gflSaveBitmap(PChar('prueba.jpg'),mOriBitmap,mSaveOption);
If I load the EXIF data and then I save them
    gflLibraryInit();
//EXIF 2
    mEXIFData2 := gflBitmapGetEXIF2(mOriBitmap);
    gflBitmapRemoveMetaData(mOriBitmap);
    gflBitmapSetEXIF2(mOriBitmap,mEXIFData2);
    gflFreeEXIF2(mEXIFData2);
there are errors in the following fields:
  • x Resolution
    y Resolution
    Exposure Time
    Focal Length
Curiously, if I load the previously saved image and I save it, EXIF data is stored correctly as in the original image. That is, the second copy retains the EXIF data correctly.
This error does not occur with other camera models
You can download an image here:
http://personal.telefonica.terra.es/web ... mg0022.jpg
Miguel Angel
http://imagen3d.site88.net
madiazg
Re: Error EXIF Data in Nikon
Post by madiazg »
have you been able to find out what the problem?
Miguel Angel
