I have enabled the theme, don't know how, I can't disable it, the background is dark and (a bug?) text in Settings dialog is white and almost unreadable.
Edit: I tried to use old ini from backup but the background is still dark. How to change it back?
XnViewMP Version 0.20 (Sep 25 2009), Windows Vista 32 bit SP2.
MP 0.20 Win - White text in settings dialog
- Attachments
- xnmpwhitetext.png (18.94 KiB) Viewed 2079 times
Dreamer
Re: MP 0.20 Win - White text in settings dialog
Try to do (to disable it):
View\Style\Theme, then delete all the theme setting text, and OK
Close XnViewMP
Restart XnViewMP
(Works with MP Linux)
To enable it:
View\Style\Theme and OK
FI: I have the same bug (White text & white check boxes) in settings dialog box too, with this dark theme, so it is not possible to use it as it is.
Close XnViewMP
Restart XnViewMP
To enable it:
Thanks, it works now, but I've tried the same way few minutes ago and it didn't work, strange.
Dreamer
- Quit XnView MP.
- Remove default.style.
- Restart XnView MP.
An other example of dark theme to copy/paste into the setting theme area (View\Style\Theme...) without the white text problem
see here: http://newsgroup.xnview.com/viewtopic.p ... 588#p77588
see here too:http://newsgroup.xnview.com/viewtopic.php?f=62&t=18469
There is a "Default" theme for resetting to default. And in dark theme one can still read the text in the settings dialog.
Closed.
