[SOLVED in RC3!] Thumbnail details in filmstrip layout
Locked
Lesmo16
Post by Lesmo16 »
There's a little flaw in the filmstrip layout. :bug:
If I select some thumbnail details to be displayed under the pictures, the hight of the filmstrip remains like it was with the filename only. xnView gives a vertical scrollbar, but that isn't the goal of the filmstrip layout. :wink:
Please check, if it is possible to adjust the filmstrip hight according the total hight of thumbnail + details.
Everyone who believes in telekinesis, raise my hand!
Re: [Flaw:] Thumbnail details in filmstrip layout
Lesmo16 wrote:There's a little flaw in the filmstrip layout. :bug:
Yes, i'll fix it
Lesmo16
Post by Lesmo16 »
Only half way fixed. :?
Lesmo16 wrote:Please check, if it is possible to adjust the filmstrip hight according the total hight of thumbnail + details.
1st half:
Now I can manually adjust the height, which wasn't possible before.
I have to increase it when I add details, and to decrease it when I remove details.
2nd (missing) half:
To be honest - I've thought of automatically hight adjustment ... :wink:
Lesmo16 wrote:Only half way fixed. :?
1st half:
2nd (missing) half:
Ok, i'll fix it
Lesmo16
Post by Lesmo16 »
Solved since RC3 - Thanks! :D
Locked
