[Fixed?] REQ: .C4 Raster32 file type support
Locked
Post by Guest »
In the previous Xnview versions the .c4 file format was supported but it seems to have gotten cut from 1.8. Can this be put back in the new version.
Re: REQ: .C4 Raster32 file type support
Anonymous wrote:In the previous Xnview versions the .c4 file format was supported but it seems to have gotten cut from 1.8. Can this be put back in the new version.
No, by default XnView use onyl some formats (a dialog is shown at startup), go to options/General/startup/Use all formats...
Post by Guest »
Why doesn't XnView support all formats by default ?
Aokromes
Post by Aokromes »
To have more speed at startup.
Aokromes wrote:To have more speed at startup.
And many users don't want any exotic formats....
Is it a problem (there is the startup dialog)??
Dreamer
Post by Dreamer »
I think this is [OK] - Can I move it to "Solved..." ?
Dreamer wrote:I think this is [OK] - Can I move it to "Solved..." ?
Yep. Closed.
Locked
