[Fixed?YES] RC2: Graphic artifact entering fullscreen from t
marsh
Post by marsh »
With tabs enabled, entering fullscreen from browser using <ctrl f> displays
a horizontal grey bar across the the top ten percent of screen.
ckit
Post by ckit »
Yes, I've been trying to make out what it is ever since 1.80 RC2 came out.
I think it has something to do with Folder Tabs?
I don't get it in Browser mode, I get it in View mode.
Re: RC2: Graphic artifact entering fullscreen from tab.
marsh wrote:With tabs enabled, entering fullscreen from browser using <ctrl f> displays
You have "tabs always" & enabled, you view a picture in fullscreen from browser and you have a bar?? Do you have a screenshot?
ckit
Post by ckit »
Here's mine (sorry about the size, I can't help going for quality :)
ckit wrote:Here's mine (sorry about the size, I can't help going for quality
Can't reproduce it, someone with the same problem?
You had the same problem in RC1???
ckit
Post by ckit »
I don't remember coming across it in RC1 and when I downloaded RC1 again it had the date stamp as RC2 so it was really RC2 :(
marsh
Post by marsh »
More than one tab must be opened to reproduce bug.
I don't remember it in RC1.
ckit
Post by ckit »
Are you including the Browser tab as well as a image file tab as one?
From what I've found the number of tabs doesn't make any difference.
marsh
Post by marsh »
ckit wrote:Are you including the Browser tab as well as a image file tab as one?
Any two tabs will reproduce problem. Close the browser tab and problem goes away (if it is one of two).
ckit
Post by ckit »
I still have the problem even with the Browser tab closed.
If I turn Folder Tabs off completely in options, the bug goes away!
marsh
Post by marsh »
Its a ghost of the folder tabs background.
OL
Post by OL »
That empty tab bar won't show up if you enter fullscreen directly from browser, only from windowed viewer.
Dreamer
Post by Dreamer »
The problem is in "standard" fullscreen only and only if Folder Tabs in menu - View > Folder Tabs is enabled.
ckit
Post by ckit »
This bug seems to affect the internal video player as well when playing in fullscreen.
Very annoying.
Dreamer wrote:The problem is in "standard" fullscreen only and only if Folder Tabs in menu - View > Folder Tabs is enabled.
Right, i'll fix it
Locked
