Self-running slideshows (slide.exe) advance to next image properly when
key is pressed, but not with mouse click. Mouse click only displays first
image and exits.
I used the following options:
Use all the images current folder and subfolder.
Use keyboard or mouse click.
No transition effects.
FullScreen.
Create EXE FullScreen.
[OK] RC2: Slide.exe does not advance properly with mouse.
Re: RC2: Slide.exe does not advance properly with mouse.
I can't reproduce it, click left go to previous picture, and click right go to next picture...marsh wrote:Self-running slideshows (slide.exe) advance to next image properly when
image and exits.
FullScreen.
Problem solved. Thank you. I misunderstood mouse navigation.xnview wrote: I can't reproduce it, click left go to previous picture, and click right go to next picture...
Therefore movedmarsh wrote:Problem solved. Thank you. I misunderstood mouse navigation.xnview wrote: I can't reproduce it, click left go to previous picture, and click right go to next picture...
