[Fixed] RC2: 'Dbl Click or enter to view in fullscreen'
Locked
deus-ex
Post by deus-ex »
With the option Dbl Click or enter to view in fullscreen enabled doubleclicking
or entering on an image does nothing. Instead Xnview does'nt respond anymore
and has to be terminated through Taskmanager. (same experience with RC1),
Then on restart of Xnview the treelist window (width) is shrinked to the left border
and has to be opened/adjusted manually.
OS: WinXP Pro SP2
Regards,
deus-ex
Hacker
Post by Hacker »
Welcome! :D
With the option Dbl Click or enter to view in fullscreen enabled doubleclicking or entering on an image does nothing. Instead Xnview does'nt respond anymore and has to be terminated through Taskmanager.
Try pressing Esc instead of starting Task Manager.
Restart XnView and activate the Preview (Ctrl-Shift-P). Then the double-click should work.
I already reported this bug. :)
Roman
deus-ex
Post by deus-ex »
Also welcome, Hacker. :)
(I think i became a Xnview forum member some time before you, around 2004)
Thank you for the reply, pressing [ESC] works, so does Double-Click/Enter, when Preview is enabled.
Regards,
deus-ex
deus-ex wrote:Thank you for the reply, pressing [ESC] works, so does Double-Click/Enter, when Preview is enabled.
Ok, a bug when preview is not enabled
deus-ex
Post by deus-ex »
Fix confirmed. :)
Regards,
deus-ex
Locked
