[Fixed] RC2: Browser item highlight
Locked
deus-ex
Post by deus-ex »
When opening a subfolder in treelist and changing to the browser with the TAB-Key
the first item in the browserwindow does'nt get highlighted. Only after pressing any of
the navigation keys (cursorkeys, pageup/down etc.) the highlighting appears.
OS: WinXP Pro SP2
Regards,
deus-ex
Re: RC2: Browser item highlight
deus-ex wrote:When opening a subfolder in treelist and changing to the browser with the TAB-Key
Ok, but do i have always to i select the first item? If it's a picture, will be loaded in preview.
marsh
Post by marsh »
xnview wrote: Ok, but do i have always to i select the first item? If it's a picture, will be loaded in preview.
No, you may not want movies, pdfs, to automatically be selected and loaded.
deus-ex
Post by deus-ex »
For me the answer to your question must be YES. I have Preview permanently
switched off. I use to switch between Browser and Treelist with the TAB-Key
so the missing highlight for the first item makes it difficult to recognice which
window currently has the focus.
As a result i frequently change the current folder by mistake because the
treelist had the focus instead of the browser.
Regards,
deus-ex
deus-ex
Post by deus-ex »
Fix confiremd. :)
Regards,
deus-ex
Locked
