I don't think this has been reported:
By default, <right click> context menu 'Open Enter' is not the same as pressing 'Enter' on keyboard. This is not consistant.
Simply renaming 'Open Enter' to 'Open' might be clearer.
[Fixed?YES] RC2: minor: RMB Open Enter not same as keyboard
Re: RC2: minor: RMB Open Enter not same as keyboard Enter
One question, Enter must be used like Dbl-click when "Dbl click to fullscreen" is enabled?? Or only dbl-click to fullscreen, and ENTER to open always??marsh wrote:I don't think this has been reported:
I'd prefer 2 options:xnview wrote:One question, Enter must be used like Dbl-click when "Dbl click to fullscreen" is enabled?? Or only dbl-click to fullscreen, and ENTER to open always??
[x] - "Dbl click to fullscreen"
[x] - "Enter to fullscreen"
- if disabled, open in viewer
- with these options I could always go to fullscreen with F11 and dbl click and always go to viewer with Enter.
And also for mouse:
[x] - "MMB click to fullscreen" (from viewer to standard / from browser to lite)
- this is already possible but the there is no option for this...
- so if it would be disabled, open in viewer, and also go from viewer back to browser with MMB
- reason (again) - MMB is redundant if "Dbl click to fullscreen is enabled"
Sorry, I tried to answer, I'll move it to "RC1: Lite Fullscreen Mode"
I think this is easier and very flexible solution to have (hope) all options needed, every user could use keys and mouse buttons he wants...
I am unsure.xnview wrote: One question, Enter must be used like Dbl-click when "Dbl click to fullscreen" is enabled?? Or only dbl-click to fullscreen, and ENTER to open always??
Think it would be good and intuitive to have menu item "Open", Enter key and Double-Click do all the same. There's surely less variations and combinations, but I think consistency is more important, here.marsh wrote:I am unsure.xnview wrote: One question, Enter must be used like Dbl-click when "Dbl click to fullscreen" is enabled?? Or only dbl-click to fullscreen, and ENTER to open always??
