I also like Dreamer's approach. Besides, the number of Filetypes available in "Most used formats" should be reduced a lot.
If possible a good solution should make it into XnView 1.80. The way it is now is in the current release candidates 1-4 is not so good.
Handling of File types
In RC4, you can choose file type wanted in save dialog.helmut wrote:I also like Dreamer's approach. Besides, the number of Filetypes available in "Most used formats" should be reduced a lot.
ckit
Well hidden. Shouldn't this at least move to the top of the category "Write"?ckit wrote:It's at the bottom of the Write list (Options -> Write -> File Types)
Or even back to the main level were it was originally? Sure enough some people mixed up file types and associations, but I think that had various reasons, one was the position of the category and the other one the unclear explanations in the option panels of file types and associations. See topic Wishlist: simplified file associations.
If we can't find a common agreement and solution quickly, we should move it at least at the top of category "Write".
Ok, perhaps better at the top. Anyone agree?helmut wrote:Well hidden. Shouldn't this at least move to the top of the category "Write"?ckit wrote:It's at the bottom of the Write list (Options -> Write -> File Types)
ckit
Dreamer
Dreamer
The Write panel is pretty empty, that's true. But combining the two panels will make them a bit less clear. For 1.80 we should keep them separate.Dreamer wrote:Yes, maybe move it to the main level - join with Write, there is just one entry there ([x] If no extension, add it).xnview wrote:Ok, perhaps better at the top. Anyone agree?
