RC4: Missing elipsis in "View in Hex mode"
Locked
In Browser, the menu says File > View in hex mode
Instead, it should say "View in Hex mode..." (notice the case and elipsis "...").
Re: RC4: Missing elipsis
helmut wrote:In Browser, the menu says File > View in hex mode
Ok
In RC5 the elipsis has been fixed but not the case.
kaptainkory
Post by kaptainkory »
Doesn't an elipsis imply that a dialogue box will open? In this case, no dialogue box is opened, so I don't understand the need for the elipsis. Please explain.
kaptainkory wrote:Doesn't an elipsis imply that a dialogue box will open? In this case, no dialogue box is opened, so I don't understand the need for the elipsis. Please explain.
Correct. There's various spots for "View in Hex mode". In "File > View in Hex mode" a dialog is opened to choose a specific file, so an elipsis should be used here.
kaptainkory
Aha, but when selecting an image in Browser and then opening a context menu, it should only be "View in Hex mode" (no elipsis) since no dialogue is opened. Right? Hmm.
kaptainkory wrote:Aha, but when selecting an image in Browser and then opening a context menu, it should only be "View in Hex mode" (no elipsis) since no dialogue is opened. Right? Hmm.
Right. This way the user will know.
kaptainkory
Well, right now the context menu says "View in hex mode...". Has this been listed as a bug elsewhere? I can't remember.
kaptainkory wrote:Well, right now the context menu says "View in hex mode...". Has this been listed as a bug elsewhere? I can't remember.
Perhaps there's one string constant only and fixing at one location made the other one wrong. Moved back to "New/Open".
kaptainkory
In RC6,
Context Menu = "View in Hex mode" (CORRECT)
File -> "View in Hex mode" (INCORRECT...should say "View in Hex mode..."
Dreamer
Post by Dreamer »
Verified fixed in RC7.
Locked
