[FIXED] RC4: Stop in browser's context menu is useless
Locked
Olive
Post by Olive »
When you right-click a thumb in the browser, you get "Stop.........ESC" in the context menu. Stop does nothing and ESC closes XnView ie same as File>Exit. I'd suggest, either remove this entry from the menu, or rename it to "Exit" (and make it actually exit the program) for consistency with File>Exit :)
marsh
Post by marsh »
Perhaps "Rename F2" is also a good candidate for removal in this particular context menu. The same thing is done by using clicking name with mouse.
marsh wrote:Perhaps "Rename F2" is also a good candidate for removal in this particular context menu. The same thing is done by using clicking name with mouse.
I'd like to keep the "Rename F2".
Re: RC4: Stop in browser's context menu is useless
Olive wrote:When you right-click a thumb in the browser, you get "Stop.........ESC" in the context menu. Stop does nothing and ESC closes XnView ie same as File>Exit. I'd suggest, either remove this entry from the menu, or rename it to "Exit" (and make it actually exit the program) for consistency with File>Exit :)
When xnview create thumbnail, ESC can stop it
Olive
Post by Olive »
^ Oh I hadn't noticed that :D
Good to know. Still the question whether it's worth while having an entry in the context menu for this. Personally, I never use Esc for stopping thumbnail creation, since it might close the browser if I press it too late. Also, I would rather press Esc than opening a context menu and select a menu item at the bottom.
That's my opinion, what do other users think?
Dreamer
Post by Dreamer »
I don't need Stop in the context menu in the browser, I'd rather have Exit there.
Olive
Post by Olive »
i think there's another topic for exit in context menu ;)
ok close isn't useless for it actually stops thumbnail creation. If Pierre thinks it's not useful to have a context menu entry for this and ESC is enough, he'll remove it. marking fixed.
Dreamer
Post by Dreamer »
Olive wrote:i think there's another topic for exit in context menu ;)
OK, sorry :wink:
Closed. There seems to be no real need for removing "Stop".
Locked
