RC5: Preview still built in two steps
helmut wrote:The speed of the smoothening (high quality) depends on the number of pixels, I guess this is the reason why Pierre uses pixels as units.
Yes, exactly
Very strongly compressed files (e.g. JPG) could have a small file size but a large number of pixels (dimension). So file size would not be fully correct. But even Pierre's current approach has a flaw, what happens if a file is 3000 pixel wide but only 10 pixel high?
Used, because it's slow here too
Hacker
Post by Hacker »
xnview wrote:
helmut wrote:
Hacker wrote:BTW: What is the value you enter there? The image size in pixels? So the default 2048 means images larger than 64*32?
Good question. I thought it would be width or height. If this is really the case, the wording for the option has to be changed.
No it's the size in width or height in pixels. So 2048 means >= 2048 x 2048
So 2048 does not include 5000*1500?
Roman
Hacker wrote:
xnview wrote:
helmut wrote: Good question. I thought it would be width or height. If this is really the case, the wording for the option has to be changed.
No, include Width > OR height >
Lesmo16
Post by Lesmo16 »
"Use delayed high quality for pictures larger than (pixel)
(browser only, also affects preview)"
I don't want to discuss the text (I just accept it), but what about writing "pixel" behind the TextBox instead where it's now?
Everyone who believes in telekinesis, raise my hand!
Bad location
:arrow: Lesmo16
:) Hi !
…but what about writing "pixel" behind the TextBox instead where it's now?
- I agree, I noticed that it isn't very logical… Forward the field should be better.
:mrgreen: K R
Lesmo16
Re: Bad location
Post by Lesmo16 »
Clo, you mean left from the TextBox? :?
IMO it's more common on the right: [2048] Pixels - like spoken.
But in fact we're talking about peanuts, right? :mrgreen:
Not a problem---
:) Not a big deal for me, I can fix up that "personally" :wink:
- Such little annoyances could be fixed up following the first step of this way… :wink:
:mrgreen: VG
Lesmo16
Re: Not a problem---
Post by Lesmo16 »
Clo wrote::) Not a big deal for me, I can fix up that "personally" :wink:
Clo, thanks for the link. 8)
I'll do some experiments ...
[OT, though…]
:D You will be welcome in the aforesaid thread, if you discover some “snags” here and there … and even if you don't ! :P
:mrgreen: VG
Olivier_G
Post by Olivier_G »
So what about my previous suggestion ?
Olivier_G wrote:Maybe we should use what Hacker mentioned previously: the number of pixels (as the surface area: width x height) ?
=> "Use 2-step high quality preview for pictures larger than [X] Mega-Pixels"
Most people know what a "Mega-Pixel" is (thanks to digital cameras) and it does represent exactly the complexity of the operation...
Hacker
Post by Hacker »
Olivier_G wrote:So what about my previous suggestion ?
Megapixel refers to the total amount of pixels, not to vertical or horizontal resolution, as in this case. For this wording to match, Pierre would need to change the way the value is checked.
Roman
Olivier_G
Post by Olivier_G »
Hacker wrote:
Olivier_G wrote:=> "Use 2-step high quality preview for pictures larger than [X] Mega-Pixels"
Exactly: my suggestion is not about wording....
It is about changing the condition itself in order to better reflect the complexity/time of the operation, which seems to be the main issue, here, given Pierre's answers.
Olivier
Yes perhaps better, but not in this release...
Olivier_G
Post by Olivier_G »
xnview wrote:Yes perhaps better, but not in this release...
OK. I understand that 1.80 has been a HUGE amount of changes and work, and agree with your answer. I wish you a good "1.80 release" :D
Thank you, Pierre.
Olivier
Olivier_G
Post by Olivier_G »
Update
Olivier_G wrote:2-pass HQ for pictures larger than [X] Mega-Pixels
This should be part of the current Options reorganization and be moved to View>High Quality Zoom options as well.
Olivier
