RC5: Double-click on non-image file locks up Xnview
From browser view, when double-clicking a file that is not an image, Xnview completely locks up. I've tested this on both a .zip file and an Excel file with the same result. (Both of these test files were about 1MB each.)
Yes, but…
- Confirmed here under Win 98 SE.
- However, I can undo the lock-up with the “ESC” key, then close XnView normally…
A couple of other things I noticed with non-image files... (Perhaps a more thorough bug hunt is in order?)
Select a non-image file in Browser. Then try these:
* Tools -> Set as Wallpaper = Several options are NOT grayed out. At least they don't do anything either.
* Tools -> Slide Show... Press OK. = Error message continues to appear when you press OK; must press CANCEL to escape out.
Looks like some other things probably should be grayed out, too, but I'll leave it to someone else to suggest others...
Re: RC5: Double-click on non-image file locks up Xnview
Yes, right...kaptainkory wrote:From browser view, when double-clicking a file that is not an image, Xnview completely locks up. I've tested this on both a .zip file and an Excel file with the same result. (Both of these test files were about 1MB each.)
Confirmed.kaptainkory wrote:FIXED
Please explain, or create new topic in "New/Open" forum and let me know (here) - then I could move this one to "Closed/Solved" forum. Thanks.kaptainkory wrote:The issues with "Set as Wallpaper" and "Slide Show..." still exist, but you may not consider these a problem.
There's a new topic "REQ: Menus not greyed out for non-image files".Dreamer wrote:...Please explain, or create new topic in "New/Open" forum and let me know (here) - then I could move this one to "Closed/Solved" forum. Thanks.kaptainkory wrote:The issues with "Set as Wallpaper" and "Slide Show..." still exist, but you may not consider these a problem.
