Add history - move back/forward
Brother Gabriel-Marie
Re: Add history - move back/forward
Post by Brother Gabriel-Marie »
Well, I used the most recent full install of XnView (1.9.6.2, I think?) and I changed skins to mezic, (I use the gnome) but nothing changed on my little toolbar. And my filter button there is always blank. Maybe I just don't know how to change the skin for the little toolbar?
:arrow: Brother Gabriel-Marie
:) Dear Brother,
• Can you see the newly installed skin in your <xnview.ini> under the [Start] section, i.e. here :
BarFilename=E:\XnVIew_190_beta\Cathy.bar
which stands for the customized *.bar file I use…
- Please, see again THE MANUAL
:mrgreen: KR
SOLVED: Add history - move back/forward
Okay, Okay, I figured it out! I went snooping in the skins folder and found that the gnome theme I was using had an info file with version 2 instead of version 4! I had tried switching to the default theme but the browser toolbar still did not change a lick. So I created a new folder called BGM and pasted the gnome toolbar into it as well as the default themes little toolbar. Then I made sure the info file inside that new skin folder read version 4 and then restarted Xnview. Now it works just fine. Thanks for y'alls help! Now I have back and forward buttons, and my filter button has an icon now too!
-BGM
