Option/fullscreen/Enable mouse navigation
Locked
I'm not sure if this option is needed, because we have option/View/keyboard/mouse. What do you think?
ckv
Post by ckv »
Hmm. Do you mean now to removing that option for good or just moving it in to 'ption/View/keyboard/mouse'?
I think it should be removed, because the double click makes it hard to use.
Any opinions ideas?
Is there someone who uses this function?
marsh
Post by marsh »
With 2 fullscreen modes, I think mouse navigation does not make sense for fullscreen (editor).
Dreamer
Post by Dreamer »
Maybe you could move it to "option/View/keyboard/mouse" > LMB / RMB as another option - no additional space required...
Anyway I don't need it, of course.
Olive
Post by Olive »
Some mouses still don't have a wheel so it may be useful. You could remove it and add Previous/Next in LMB/RMB dropdown lists (keyboard/ mouse options)
Olive wrote:Some mouses still don't have a wheel so it may be useful. You could remove it and add Previous/Next in LMB/RMB dropdown lists (keyboard/ mouse options)
Yes, but this will be used in view AND fullscreen, not only fullscreen. So i don't change...
Olive
Post by Olive »
Yes, perso I've got a 5-button mouse for years but some guys I know are still using 2-button mouses, so I think it's safer as it is now :D
Olive wrote:Yes, perso I've got a 5-button mouse for years but some guys I know are still using 2-button mouses, so I think it's safer as it is now :D
:P Yep ! Using 2-button mice still in THIS country seems crazy !
Sorry for OT…
:mrgreen: KR
Dreamer
Post by Dreamer »
Not changed/resolved, therefore (re)moved.
Locked
