[Fixed in RC7] Tooltips in Options dialog
Locked
Lesmo16
Post by Lesmo16 »
There's a minor flaw in Options dialog.
The following 3 entries have a tooltip - the others don't:
- in Category View: "Quick Slide Show" and "Keyboard/Mouse"
- in Category Toolbar: "Buttons displayed"
Either all with, or all without tooltip - IMO it should be without. :wink:
Everyone who believes in telekinesis, raise my hand!
Re: [Flaw:] Tooltips in Options dialog
Lesmo16 wrote:There's a minor flaw in Options dialog.
That's a feature of Windows for items which are not fully shown. Perhaps the category panel could be a bit wider so that all entries can be fully seen.
Lesmo16
Post by Lesmo16 »
:shock: Oops - your right - I didn't know that ...
... moving the horizontal scrollbar fixes this "flaw"!
Fixed in RC6! :mrgreen:
Pierre could you please check whether the category panel could be made a bit wider so that these labels are not truncated (sure enough they might be truncated in other languages). Either mark this one as fixed, postponed, or closed, whichever you prefer. ;-)
helmut wrote:Pierre could you please check whether the category panel could be made a bit wider so that these labels are not truncated (sure enough they might be truncated in other languages). Either mark this one as fixed, postponed, or closed, whichever you prefer. ;-)
Ok, make it a bit wider
ckit
Post by ckit »
This has been changed in RC7.
Lesmo16
Post by Lesmo16 »
Fixed! :)
Locked
