0.39 Beta win 64: SVG files are not displayed in browser
idji
Post by idji »
when browsing files using XnViewMP internal browser with following setting (these were default for me as I have changed nothing since downloading):
• Filter = All
• View As = Thumbnails + Labels
then all files except *.SVG are shown, but SVG ones are not even visible via browser window.
When I drag and drop my "Test.SVG" into XnViewMP window it is opened with label "<Empty>" in place of filename (other files show filename correctly in this case).
If an SVG file is dragged into tab with other image opened the filename is shown correctly.
If there is any quickfix I'll greatly appreciate any help.
Anyway best regards, Vlad.
Re: 0.39 Beta win 64: SVG files are not displayed in browser
Vlad, you have to remove svg (and svgz) from the exclusion list in Tools » Settings... » Browser » Files list » Custom filter.
