When loading XnView 1.80 RC7 you can a "flicker" effect in the top left-hand corner of the screen (where the toolbar begins and the first folder tab)
I ran some tests and found that it had nothing to do with the toolbar or folder tabs instead I suspect it has something to do with fixing "XnView can't remember layouts" bug.
RC7: Flickering on Startup
Re: RC7: Flickering on Startup
Yes, i fix it...ckit wrote:When loading XnView 1.80 RC7 you can a "flicker" effect in the top left-hand corner of the screen (where the toolbar begins and the first folder tab)
... just for a perfect look!xnview wrote:Yes, i fix it...ckit wrote:When loading XnView 1.80 RC7 you can a "flicker" effect in the top left-hand corner of the screen (where the toolbar begins and the first folder tab)
Everyone who believes in telekinesis, raise my hand!
