Is it possible to post a list of all new/changed strings between 1.74 and 1.80?
X.
List of new strings for 1.80
Re: List of new strings for 1.80
Why?Xyzzy wrote:Is it possible to post a list of all new/changed strings between 1.74 and 1.80?
New strings in string<xx>.h
New strings in xnview<xx>.h
#define TXT_String_Info_Pages "Pages"
#define TXT_String_Info_DPI "DPI"
#define TXT_String_Operation_Successfull "Operation successful"
#define TXT_String_No_File_Found "No files found"
#define TXT_String_Convert_1 "Convert ""%s"""
#define TXT_String_Startup "Startup"
#define TXT_String_Recent_Lists "Recent lists"
#define TXT_String_General "General"
#define TXT_String_Thumbnail_Labels "Thumbnail Label"
#define TXT_String_Tabbar "Folder tabs"
#define TXT_String_Quick_Show "Quick Slide Show"
#define TXT_String_Switch_Config "Switching modes"
#define TXT_String_3D_Border "3D border"
#define TXT_String_Drop_Shadow "Drop shadow"
#define TXT_String_Comment "Comment"
#define TXT_String_Name_Descending "Name (descending)"
#define TXT_String_Date_Descending "Date (descending)"
#define TXT_String_Size_Descending "Size (descending)"
#define TXT_String_Extension_Descending "Extension (descending)"
#define TXT_String_Copy_Folder_Exist "This folder have already a subfolder with the same name\nIf some existing files or folder have the same name than files from folder that you want to copy or move, they will be replaced. \n\nDo you want to copy or move this folder?"
#define TXT_String_Ask_Formats "By default only the most common formats are available for loading/saving. If you want to have special formats, also, please visit the options, category ""General > Startup"""
#define TXT_String_Thumb_Bad_Template "There is no ""thumb.html"" in this template folder!"
#define TXT_String_Quick_SlideShow "Quick Slide Show"
#define TXT_String_Adjust "Adjust Brightness/Contrast/Gamma/Balance"
#define TXT_String_RedEyes "Remove red eye"
#define TXT_String_FileOp "File operations"
#define TXT_String_Search "Search files"
#define TXT_String_Rotate_Clockwise "Rotate clockwise"
#define TXT_String_Goto_Page "Page #"
#define TXT_String_TB_Open "Open"
#define TXT_String_TB_View "View"
#define TXT_String_TB_Save_As "Save as"
#define TXT_String_TB_Undo "Undo"
#define TXT_String_TB_Zoom_In "Zoom in"
#define TXT_String_TB_Zoom_Out "Zoom out"
#define TXT_String_TB_Fullscreen "Fullscreen"
#define TXT_String_TB_Print "Print"
#define TXT_String_TB_Convert "Convert"
#define TXT_String_TB_Capture "Capture"
#define TXT_String_TB_Slide_Show "Slide show"
#define TXT_String_TB_Options "Options"
#define TXT_String_TB_About "About"
#define TXT_String_TB_Refresh "Refresh"
#define TXT_String_TB_Thumbnail_Create "Web pages"
#define TXT_String_TB_ContactSheet "Contact Sheet"
#define TXT_String_TB_JpegTransform "Rotation"
#define TXT_String_TB_Informations "Properties"
#define TXT_String_TB_Zoom_Org "Zoom 100%"
#define TXT_String_TB_Scan "Scan"
#define TXT_String_TB_Previous_File "< File"
#define TXT_String_TB_Next_File "File >"
#define TXT_String_TB_Previous_Page "< Page"
#define TXT_String_TB_Next_Page "Page >"
#define TXT_String_TB_Quick_SlideShow "Quick-Show"
#define TXT_String_TB_Adjust "Adjust"
#define TXT_String_TB_RedEyes "Red eyes"
#define TXT_String_TB_FileOp "File"
#define TXT_String_TB_Search "Search"
#define TXT_String_TB_ViewAs "View as"
#define TXT_String_TB_Sort "Sort by"
#define TXT_String_TB_Bookmark "Favourite"
#define TXT_String_File_Association "%s Image"
#define TXT_String_FileOp_Copy1 "%sCopy of %s"
#define TXT_String_Text_Files "Text file (*.txt)"
#define TXT_String_EXE_StandAlone_Files "Application (*.exe)"
#define TXT_String_SCR_ScreenSaver_Files "Screen Saver (*.scr)"
#define TXT_String_Previous_Next_File "Previous/Next file"
#define TXT_String_Scroll_left_right "Scroll left/right"
#define TXT_String_Scroll_up_down "Scroll up/down"
#define TXT_String_Move_Selection "Move selection"
#define TXT_String_Zoom "Zoom"
#define TXT_String_Make_Selection "Make selection"
#define TXT_String_Move_Picture "Move picture"
#define TXT_String_Viewer_Full_Browser_Full "Browser <> Fullscreen | Viewer <> Fullscreen"
#define TXT_String_Viewer_Browser "Browser <> Viewer"
#define TXT_String_Browser_Viewer_Full "Browser > Viewer > Fullscreen"
#define TXT_String_Browser_Full_Viewer "Browser > Fullscreen > Viewer"
#define TXT_String_Cross_Fading "Cross-fading"
#define TXT_String_All_Effects "All effects"
#define TXT_String_Infos_File_Created_Date "File created date"
#define TXT_String_Infos_File_Created_Time "File created time"
#define TXT_String_Infos_File_Modified_Date "File modified date"
#define TXT_String_Infos_File_Modified_Time "File modified time"
#define TXT_String_Infos_File_Size "File size"
#define TXT_String_Infos_File_Type "File type"
#define TXT_String_Infos_Image_Info "Image properties"
#define TXT_String_TabTitle_Folders "Folders"
#define TXT_String_TabTitle_Favorites "Favourites"
#define TXT_String_Reading_Data_From_Device "Reading data from the device (%d%% complete)"
#define TXT_String_Processing_Data "Processing data (%d%% complete)"
#define TXT_String_Transferring_Data "Transferring data (%d%% complete)"
#define TXT_NviewMenu_Auto_Levels "Automatic levels"
#define TXT_NviewMenu_Auto_Contrast "Automatic contrast"
#define TXT_NviewMenu_Export_EXIF_TXT "Export EXIF data as text..."
#define TXT_NviewMenu_Export_EXIF_CSV "Export EXIF data as CSV..."
#define TXT_NviewMenu_Export_EXIF_XML "Export EXIF data as XML..."
#define TXT_NviewMenu_Edit_Tiff "Edit Multipage TIFF...\tAlt+E"
#define TXT_NviewMenu_Slideshow_Start "Start Quick Slide Show\tPause"
#define TXT_NviewMenu_Binary_NoDither "Binary (No Dither)"
#define TXT_NviewMenu_Swap_Width_Height "Selection - Swap width && height\tTab"
#define TXT_NviewMenu_Same_As_Image "Same as image\tD"
#define TXT_NviewMenu_Free "Free\tA"
#define TXT_NviewMenu_Effects2 "Effects..."
#define TXT_NviewMenu_Jpeg_Lossless_Trans "JPEG Lossless transformations"
#define TXT_NviewMenu_Jpeg_Dialog "Dialog..."
#define TXT_NviewMenu_Jpeg_Rotate_90_Left "Rotate 90° left\tCtrl+Shift+L"
#define TXT_NviewMenu_Jpeg_Rotate_90_Right "Rotate 90° right\tCtrl+Shift+R"
#define TXT_NviewMenu_Attach_Images "Attach images..."
#define TXT_NviewMenu_Multipage "Multipage"
#define TXT_NviewMenu_Create "Create..."
#define TXT_NviewMenu_Scanner_Camera_WIA "Acquire from Scanner or Camera (WIA)..."
#define TXT_NviewMenu_Tab_Window "Folder tabs"
#define TXT_NviewMenu_Remove_Metadata "Remove All Metadata"
#define TXT_NviewMenu_Tips "Tip of the day..."
#define TXT_BrowseMenu_Comment "Comment (embedded)"
#define TXT_BrowseMenu_Associated_Program "Associated Program\tF3"
#define TXT_BrowseMenu_Associated_Editor "Associated Editor\tF4"
#define TXT_BrowseMenu_View_Thumb_Detail "Thumbnails && Details"
#define TXT_BrowseMenuFile_View_Fullscreen "View in Fullscreen"
#define TXT_BrowseMenu_Compare "Compare..."
#define TXT_Menu_Quick_SlideShow "Quick Slide Show\tSpace"
#define TXT_Menu_Quick_SlideShow_Configure "Configure Quick Slide Show..."
#define TXT_TreeFolder_Rename "Rename"
#define TXT_TreeFolder_Delete "Delete"
#define TXT_TreeFolder_Slide "Start slideshow"
#define TXT_TreeFolder_RecurseSlide "Start slideshow (recurse)"
#define TXT_TreeFolder_Open_MSExplorer "Explorer"
#define TXT_TemplateMenu_Zoom "Zoom"
#define TXT_TemplateMenu_Date_Format_Var "Date format variables"
#define TXT_TemplateMenu_Date_Sample "Sample : <Date [Y.m.d]>"
#define TXT_TemplateMenu_Year "Y - Year""
#define TXT_TemplateMenu_Year_Without_Century "y - Year without century (00-99)""
#define TXT_TemplateMenu_Month "m - Month as decimal (01-12)""
#define TXT_TemplateMenu_Day "d - Day as decimal (01-31)""
#define TXT_TemplateMenu_Hour "H - Hour (01-24)""
#define TXT_TemplateMenu_Minute "M - Minute (00-59)""
#define TXT_TemplateMenu_Second "S - Second (00-59)""
#define TXT_TemplateMenu_Month_Name "B - Month name (eg. february)""
#define TXT_TemplateMenu_Abbreviated_Month_Name "b - Abbreviated month name (eg. feb)""
#define TXT_TemplateMenu_Weekday_Name "A - Weekday name (eg. wednesday)""
#define TXT_TemplateMenu_Abbreviated_Weekday_Name "a - Abbreviated weekday name (eg. wed)""
#define TXT_TemplateMenu_Filename_Withext "Filename with extension"
#define TXT_Conv_NoDither "No dither"
#define TXT_Option_Select_New_Files "Automatically select new files"
#define TXT_SaveAs_Use_Same_Original "For 'Save as', use same original pathname && format"
#define TXT_Option_Info_Status "Info in status bar"
#define TXT_Option_Write_MSBF "Use MSBF order"
#define TXT_Option_Following_Action "If no files are selected, use following files for actions"
#define TXT_Option_None "None"
#define TXT_Option_Use_Current_Folder "Use all image files in current folder"
#define TXT_Option_Use_Current_Folder_SubFolder "Use all image files in current folder and its subfolders"
#define TXT_Convert "Convert"
#define TXT_Option_Different_Position "Use different position/size for browser && view"
#define TXT_SaveAs_Use_New_Name "After 'Save as', change filename"
#define TXT_Use_Embedded_Thumbnail "Use Embedded thumbnail"
#define TXT_No_PDF_Thumbnail "No thumbnail for PDF/PS/AI files"
#define TXT_Option_Use_Shadow "Use shadow"
#define TXT_Stretch_Small_Pictures "Stretch small pictures"
#define TXT_Option_Use_All_Formats "Use all formats available"
#define TXT_Option_Only_One_Strip "Only one strip"
#define TXT_Option_Thumb_Title "You can choose 10 entries maximum"
#define TXT_Option_Hide_Tab_When_One_Tab "Hide tab bar when only one window is opened"
#define TXT_Option_No_Thumb_In_Tab "No thumbnail in folder tab"
#define TXT_Option_Use_External_Player_Video "Use external media player"
#define TXT_Dblclick_Enter_Fullscreen "Double-click or enter to view in fullscreen"
#define TXT_Option_Display_PDF "Display PDF/EPS/PS files"
#define TXT_Option_Tree_One_Click "Single click to expand folder tree"
#define TXT_Add_Exit_In_PopupMenu "Add 'Exit' to context menus"
#define TXT_Option_Left_Dbl_Click "Use double click to switch between:"
#define TXT_Option_Middle_Click "Use middle mouse click to switch between:"
#define TXT_Option_Enter "Use ENTER to switch between:"
#define TXT_Left_Mouse "Left Mouse Button"
#define TXT_Right_Mouse "Right Mouse Button"
#define TXT_Option_Dual_Monitor_Stretch "Dual monitor, Stretch over all monitors"
#define TXT_Option_Dual_Monitor_Use_Other "Dual monitor, Use second monitor (Browser only)"
#define TXT_Slide_Use_Gamma_In_EXE "Use Gamma setting in EXE/SCR"
#define TXT_Option_Delay_for_High_Quality "Use delayed high quality for pictures larger than (pixel)"
#define TXT_Option_Limit_Tab_Caption "Limit tab caption to"
#define TXT_Option_Characters "characters"
#define TXT_Option_Use_Huge_Thumbnail "Use huge thumbnails"
#define TXT_EffectTitle "Effects"
#define TXT_Adjust_Before "Before"
#define TXT_Adjust_After "After"
#define TXT_Adjust_Default_Values "Default values"
#define TXT_Adjust_Previous_Values "Previous values"
#define TXT_Adjust_Apply_To_Picture "Apply to image"
#define TXT_Adjust_Parameters "Parameters"
#define TXT_Slide_Sort "Sort>>"
#define TXT_Slide_Transition_Effect "Use transition effects"
#define TXT_Rename_Case_Sensitive "Case sensitive"
#define TXT_Rename_Name_Template "Name template"
#define TXT_Rename_Extension "Extension"
#define TXT_Rename_Case "Case"
#define TXT_Rename_Create_Template "Create new Name template when opening dialog"
#define TXT_Rename_DblClick_New_Template "Double-Click on a file creates a new Name template"
#define TXT_Rename_Sort "Sort"
#define TXT_Slide_Create_EXE_SCR "Create EXE/SCR..."
#define TXT_Thumb_Template_Folder "Template folder"
#define TXT_Thumb_Template "Template"
#define TXT_Thumb_Header "Header"
#define TXT_Thumb_Sort_by "Sort by"
#define TXT_Thumb_Thumbnail "Thumbnail"
#define TXT_Thumb_Picture "Picture"
#define TXT_Thumb_No_HTML_Page "No HTML page per picture"
#define TXT_Thumb_Size_Maximum "Size maximum"
#define TXT_Thumb_Original_SubFolder "Original sub-folder"
#define TXT_Thumb_Thumbnail_SubFolder "Thumbnail sub-folder"
#define TXT_Thumb_Thumbnail_Prefix "Thumbnail prefix"
#define TXT_Thumb_Sharpen "Sharpen"
#define TXT_CSheet_Outlined "Outline"
#define TXT_Reset_EXIF_Orientation "Reset EXIF orientation value"
#define TXT_Jpeg_Rotate_EXIF "Rotate based on EXIF value"
#define TXT_DPI_Change_Exif "Change EXIF DPI if exists"
#define TXT_Scan_Digit "digit(s)"
#define TXT_Scan_Multi_Page "Save as Multipage (TIFF)"
#define TXT_Text_Opacity "Opacity"
#define TXT_Iptc_Clear "Clear"
#define TXT_Iptc_Previous "<Previous"
#define TXT_Iptc_Next "Next>"
#define TXT_Iptc_Write_All "Write all selected"
#define TXT_Iptc_Leave_Existing "Leave existing field if new entry is empty"
#define TXT_Iptc_Replace_Existing "Only replace existing fields that are empty"
#define TXT_Iptc_Merge_Existing "Merge with existing values (keywords && supplemental categories)"
#define TXT_TipTitle "Tip of the day"
#define TXT_Tip_Prev "Previous"
#define TXT_Tip_Next "Next"
#define TXT_Tip_Close "Close"
#define TXT_Tip_Again "Do not show tips at startup."
#define TXT_Overwrite_Title "File already exists"
#define TXT_Write_Replace "Replace"
#define TXT_Write_With "With"
#define TXT_Write_Skip "Skip"
#define TXT_Write_Rename "Rename"
#define TXT_Tiff_Title "Edit multipage TIFF..."
#define TXT_Tiff_Add_Picture "Add picture..."
#define TXT_Tiff_Overwrite_file "Overwrite current file"
#define TXT_Tiff_High_Quality "High quality for thumbnail"
#define TXT_Tiff_Options "TIFF options..."
#define TXT_Tiff_Compression "Compression"
#define TXT_Tiff_No_Compression "No compression"
#define TXT_ScrTitle "Create EXE/SCR Slideshow"
#define TXT_Scr_Display_Area "Display Area"
#define TXT_Image_Size "Image size"
#define TXT_Fixed_Size "Fixed size"
#define TXT_ListingTitle "Generate file listing"
#define TXT_Listing_Header "Header"
#define TXT_Listing_Include_Full_Path "Include the full path"
#define TXT_MultiExtrTitle "Extract page from Multi-Page file"
#define TXT_CompareTitle "Compare pictures"
Some of this is code and cannot be changed, but it still sounds like improper English.
Better
"This folder already has a subfolder with the same name\n\nIf the existing files or folders have the same name as files from the folders that you want to copy or move, they will be replaced. \n\nDo you want to copy or move this folder?"
Better
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
** XnView ROCKS **
Here is another from Tip of the Day.
By default only the most common formats are available for loading/saving. If you want to have special formats, also, please visit the options, category "General > Startup"
Better
By default only the most common formats are available for loading/saving. If you want to have special formats, please visit "General > Startup" in Options.
Better
** XnView ROCKS **
** XnView ROCKS **
