Full support for zip and rar files
Euphoria
Re: Full support for zip and rar files
Post by Euphoria »
heimaki wrote:i wonder why should i store images in a zip? most modern image formats are compressed already, so i fail to see any advantage of doing so.
The reasons are numerous, and storing images in ZIP or RAR format is not often about compression, but that is also a valid reason for popular image formats that are not compressed.
Often people have a library that consists of many images and it can be efficient to consolidate those images into a ZIP file, much in the same way as a Virtual disk might operate.
For example, someone with a large collection of images may want to consolidate images into a ZIP/RAR file to help mitigate file fragmentation across the drive, and/or to reduce wasted cluster space on a given filesystem.
Also, utilizing ZIP or RAR to compress images that do not support compression or files that need to remain natively uncompressed in a workflow would allow the ability to add transparent compression of images without violating the workflow environment.
There are a number of file formats that can be saved without compression, or that do not support compression, or need to remain uncompressed for compatibility with various other programs. BMP, uncompressed TIFF, uncompressed PNG, TGA, just to name a few.
heimaki
Post by heimaki »
a ZIP will be fragmented too, and cluster size on modern files systems are that small, it' not worth bothering at all (NTFS has 4kb as standard even on 4TB drives).
seriously, who uses BMP or TGA these days? why would i use uncompressed PNG or TIFF?
and every time you open an image in your archive it has to be unpacked into a temp directory. again and again and again.
but hey, if the devs gonna implement it in xnview, i don't mind, but apparently they aren't too keen on doing it.
osiris2258
Post by osiris2258 »
Any word on proper archive support yet? Still stuck with ACDSee here.
osiris2258
Actually to be precise still stuck on a old version of ACDSee since it's gotten so bloated. I would really like to move to XnView, if it would just get full archive support.
