Fails to start XnView MP 0.64
PiTRiS
Re: Fails to start XnView MP 0.64
Post by PiTRiS »
If it's any help, here are the two ini files - one which works ok, other which crashes xnview. Problem is clearly in "geom" setting
PiTRiS
Post by PiTRiS »
one more thing - if i choose startup folder as "none", XN starts fine
PiTRiS wrote:one more thing - if i choose startup folder as "none", XN starts fine
Please sned me your email by PM
PiTRiS
Post by PiTRiS »
Sent. The bug is still present in 0.71 I've just tried.
CoSpi
Post by CoSpi »
Hello, I have similar problem with version 0.72 x64 (Dec 19 2014) on Windows 8.1.
When I open *.jpg from Total Commander and than double click to switch to browser it crash. Next time when I open XnViewMP from shortcut it keep crashing until set PathBrowser in xnview.ini to empty or if I set start folder to empty.
CoSpi wrote:Hello, I have similar problem with version 0.72 x64 (Dec 19 2014) on Windows 8.1.
Do you have the crash dialog?
