Hello to all,
Does anybody know what, under "View" menu, "Update database from files" & "Update files From database" do exactly ???
... Is it only for selected files?, only the related folder, or for all the files already into db?, takes care (or not) of the settings into the ini file ?, rebuild thumbnails or not ? synchronize IPTC/XMP keywords, categories, or not ?, etc..???
... Because I'm a little afraid to use "these massive tools" (without knowing what I am exactly doing, and without a good notice) ???
FI: For me "massive tools" should only be available into "batch convert" processus ("Batch" basically mean for me "massive" ... so it is enough explicit)
Q: Update database from files & Update files From database ?
oops66
m.Th.
Re: Q: Update database from files & Update files From databa
Both of them deal with metadata. The 1st read the metadata from XMP sidecars (if present) and write it in the DB and the 2nd writes/generates XMP sidecars with the corresponding metadata stored in DB (Rating, Color, Keywords = RCK) for each file.oops66 wrote:Hello to all,
Yes. But it looks in subfolders also. Hence, it is enough to select the root folder only.
Which settings?
Not. Just metadata workings here.
Yes for all the RCK info.
Not quite. Batch Convert deals with the image (pixels). Catalog-Sidecar Sync primitives (like they are known in other programs) deals with metadata. Every other program has them in a separated menu, like us.
Also, Cut and Copy are "massive tools", no?
m. Th.
oops66
... For me, recursive behavior, means also for me "massive behavior" (so "massive tools")m.Th. wrote:Both of them deal with metadata. The 1st read the metadata from XMP sidecars (if present) and write it in the DB and the 2nd writes/generates XMP sidecars with the corresponding metadata stored in DB (Rating, Color, Keywords = RCK) for each file.oops66 wrote:Hello to all,
... Only from XMP sidecars files (if present), or also for IPTC or XMP embedded metadatas ?Yes. But it looks in subfolders also. Hence, it is enough to select the root folder only.
... Recursive behavior, means for me "massive behavior" ("massive tools")Which settings?
... For: "Update files From database"
And for the behavior: "do no touch the original files by default"
EX:
Settings\Metadata\IPTC & XMP \
Keywords
x Export DB Category to XMP subject and IPTC keyword
x Export rating in XMP metadata
x Export color label in XMP metadata
Comment
x Write comment in XMP (dcdescription and exifrusercomment)
...Not. Just metadata workings here.
... The embedded thumbnail into a jpg file is also a metadata, no?Yes for all the RCK info.
"Batch Convert deals with the image (pixels)" ... not only, can also manage EXIF, ... or ... IPTX/XMP metadata
see here:
http://newsgroup.xnview.com/viewtopic.p ... 08#p119608
Also, Cut and Copy are "massive tools", no?But they are somewhere else than in Batch Convert...
Thank you for these information @m.Th. ... but I think than a help is needed for these 2 complicated tools to clarify the behavior, and to know exactly what they do.
