Sample is attached. It causing XnView to crash, even when just browsing directory contents.
XnView 2.22 32-bit under Windows XP
certain images causing a crash
CreativeWorld
Re: certain images causing a crash
if you have only this picture file in a folder, crash?
CreativeWorld
It doesn't matter. Initally I've found it when I browsed a folder with thousands of files.xnview wrote:if you have only this picture file in a folder, crash?
i can't reproduce the crash
CreativeWorld
It crashes with message
8BIM is somewhat related to file format processing.
There is a dword comparison at that addressThe instruction at 0x0054e0b0 referenced memory at 0x003c1000. The memory could not be read.
.text:0054E0B0 cmp dword ptr [eax+ecx], 'MIB8'
