When using files with fractions (decimal point) at the end of GPS position, the position is not shown correctly on the map.
For example (see the attached file), the information in exifTool is OK:
GPS Position 33 deg 53' 20.65" S, 151 deg 11' 24.51" E
But it redirects to:
https://tools.wmflabs.org/geohack/geoha ... 1.190140_E_
Edit: MS Windows file properties shows this:
33; 53; 20.64720000000....
151; 11; 24.505600000....
0.72 - Wrong GPS position on the map
Re: 0.72 - Wrong GPS position on the map
From what I can see, location is exact, now (Xing Eastern Ave, Princes Hwy).
Closed (Please post here in case the problem should still occur.)
