0.75: small error with image viewer
herb
Post by herb »
Hello
XnViewMP 0.75 has the following small error in image viewer:
Menu: Image -> Adjust -> enhance colors [levels] [shadow/highlist] and [conbright]
opens a dialog which allows to store the selected values as preset with an user-defined name.
In case of entering an identical name for different presets this name is given twice in selection box.
It looks like that both have identical values. And e.g. after a restart of XnViewMP only one of these entries is available.
Best regards
Herb
Re: 075: small error with image viewer
See Issue 724 for current status and details.
Re: 0.75: small error with image viewer
Just tried with v0.84 and this works fine: When saving a preset you can either enter a new name or use an existing. Existing presets are overwritten when using the same name.
:arrow: Closed
