yes, this one works, thanks.
it is the same as the one in the link above.
FLIF support?
kwukduck
Re: FLIF support?
I can't get it to work properly?heimaki wrote:yes, this one works, thanks.
It does save the file in the program folder as C but that's it.
No additional options available?
heimaki
Re: FLIF support?
no options can be set i'm afraid.this should be changed in xnview itself. right now, the file is saved as lossless.
badon
Re: FLIF support?
Any news? I was disappointed by lossy WebP. It's not a significant improvement over old-fashioned JPEG. However, WebP is much superior than PNG for lossless, and apparently FLIF beats WebP and does a lot of other things better. I neeeeed....
