Bug Report: Contact Sheet problem
Locked
waltpalmer
Post by waltpalmer »
Version 1.80.1 (registered)
When I create a contact sheet, the images remain thumbnail sized. They do not fill the space allocated for them. This behavior has changed from previous versions, thus I suspect a bug has been introduced.
e.g.- create a contact sheet that is 4500x3600 pixels. Define 5 columns and 4 rows. This defines each image's display area as approx 900x900 pixels; but rather than fill this area with the image, the program leaves a tiny thumbnail surrounded by a large blank field.
Otherwise, thanks for a great program!
Walt Palmer
Colorado, USA
Re: Bug Report: Contact Sheet problem
waltpalmer wrote:Version 1.80.1 (registered)
This problem is fixed in 1.80.2
Locked
