Impossible to install on Ubuntu 16.04 LTS
hoppicker
Post by hoppicker »
Hi there,
Cannot install Xnview on Ubuntu 16.04 LTS.
1 With Ubuntu installer, error message (in french, sorry) : Ce logiciel provient d'une tierce partie et est susceptible de contenir des éléments non libres.
2 With sudo apt-get install /home/bernard/Bureau/XnViewMP-linux-x64.deb, :
Paramétrage de xnview (0.79) ...
N: Can't drop privileges for downloading as file '/home/bernard/Bureau/XnViewMP-linux-x64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission non accordée)
3 With sudo dpkg -i XnViewMP-linux-x64.deb et sudo apt-get install -f :
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
0 mis à jour, 0 nouvellement installés, 0 à enlever et 9 non mis à jour.
Xnview doesn't run (when starting the program, timer is in progress and at the end: nothing, nada, rien !)
4 With sudo apt-get install /home/bernard/Bureau/XnViewMP-linux-x64.tgz
E: Unsupported file /home/bernard/Bureau/XnViewMP-linux-x64.tgz given on commandline
5 and finally the PPA https://launchpad.net/~noobslab/+archiv ... hotography doesn't work.
Any idea how to install XnView?
Re: Impossible to install on Ubuntu 16.04 LTS
please try to decompress the .tgz package
hoppicker
Post by hoppicker »
OK dpkg is done, but when running sh i've got this issue:
$ sudo sh /home/bernard/Téléchargements/XnView/xnview.sh
[sudo] Mot de passe de bernard :
/home/bernard/Téléchargements/XnView/XnView: error while loading shared libraries: libgstapp-0.10.so.0: cannot open shared object file: No such file or directory
you need to install gstreamer
hoppicker
Post by hoppicker »
Thanks for your help.
Is it possible to replace gstreamer because it doesn't install too?
bernard@bernard:~$ sudo add-apt-repository ppa:ddalex/gstreamer
This PPA brings in updated version of GStreamer packages.
Plus d’info : https://launchpad.net/~ddalex/+archive/ubuntu/gstreamer
Appuyez sur [ENTRÉE] pour continuer ou Ctrl-C pour annuler l’ajout
gpg: le porte-clefs « /tmp/tmp0muif5dy/secring.gpg » a été créé
gpg: le porte-clefs « /tmp/tmp0muif5dy/pubring.gpg » a été créé
gpg: demande de la clef 4BBC8F7F sur le serveur hkp keyserver.ubuntu.com
gpg: /tmp/tmp0muif5dy/trustdb.gpg : base de confiance créée
gpg: clef 4BBC8F7F : clef publique « Launchpad PPA for ddalex » importée
gpg: Quantité totale traitée : 1
gpg: importées : 1 (RSA: 1)
OK
bernard@bernard:~$ sudo apt-get update
Atteint:1 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial InRelease
Atteint:2 http://archive.canonical.com/ubuntu xenial InRelease
Ign:3 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial InRelease
Réception de:4 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial-updates InRelease [94,5 kB]
Ign:5 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial Release
Ign:6 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main amd64 Packages
Ign:7 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main i386 Packages
Ign:8 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main all Packages
Atteint:9 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial-backports InRelease
Réception de:10 http://ubuntu.mirrors.ovh.net/ftp.ubuntu.com/ubuntu xenial-security InRelease [93,3 kB]
Ign:11 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main Translation-fr_FR
Ign:12 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main Translation-fr
Ign:13 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main Translation-en
Ign:14 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:15 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main DEP-11 64x64 Icons
Err:6 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main amd64 Packages
404 Not Found
Err:7 http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial/main i386 Packages
404 Not Found
188 ko réceptionnés en 3s (50,2 ko/s)
W: The repository 'http://ppa.launchpad.net/ddalex/gstreamer/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ppa.launchpad.net/ddalex/gstream ... 4/Packages 404 Not Found
E: Failed to fetch http://ppa.launchpad.net/ddalex/gstream ... 6/Packages 404 Not Found
E: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
bernard@bernard:~$ sudo apt-get install gstreamer
E: Impossible de trouver le paquet gstreamer
bernard@bernard:~$
try
libgstreamer0.10-0
hoppicker
Post by hoppicker »
Always the same error about shared libraries
bernard@bernard:~$ sudo apt-get install libgstreamer0.10-0
OK
bernard@bernard:~$ sudo sh /home/bernard/Téléchargements/XnView/xnview.sh
So after a search, i've installed libgstreamer0.10-dev and libgstreamer-plugins-base0.10-dev
bernard@bernard:~$ sudo apt-get install libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev
and miracle, XnView works!
Thanks for the help and a long life to XnView!
