How to filter files (showed in subfolders) by type and name?
cadu
Post by cadu »
I would appreciate help:
I'm using the option "show files in subfolder" in order to visualize contend (XnView 0.81).
The issue is that I have files with same name and different extensions. For instance:
arrow1.psd
arrow2.psd
line1.psd
How to filter XnView in order to show just files with extention "psd" and "arrow" in name?
It should return just:
arrow1.psd
arrow2.psd
step1-My first thought was to use the "filter by" functionality in order to keep just the .psd files, but I couldn't see how to perform it.
step2-Then, by using the "quick search", I would type "arrow" and XnView should show the files I need. But since I couldn't filter just the .psd files first (step1), when I type arrow both .png and .psd files are showed.
Thanks,
Carlos_
Erixx haxx
Re: How to filter files (showed in subfolders) by type and n
Post by Erixx haxx »
Hello:
Please See:
Options>> File List>> Custom Filter- tab
See If this helps...
As a workaround, you could use wildcards (Filename: a*.psd) in Tools » Search... (Ctrl+F) and activate Recurse through subfolders.
Related request: Include subfolder in quick search
cadu
Post by cadu »
Thanks for info!!!
