FullScreen: Not Tagging Files with keyboard shortcut
Erixx haxx
Post by Erixx haxx »
Hello:
While inside Fullscreen you can no longer tag files via keyboard shortcut (Spacebar).
Pretty sure this worked a while back.
Win7x64 pro
XnviewMP v0.79 - 0.82 B3 x64
Thanks
Moderator & Librarian
Re: FullScreen: Not Tagging Files with keyboard shortcut
I can't get it to work in view mode of v0.79 and v0.81 either (default and customized shortcut).
It's Ctrl+T, in XnView Classic you have spacebar too
Erixx haxx
I tried with spacebar (fullscreen) and it doesn't work
Erixx haxx wrote:I tried with spacebar (fullscreen) and it doesn't work
only in XnView Classic :)
Erixx haxx
Ok I see now. In MP it is CTR+T
Then under options panel>> keyboard shortcuts is wrong
Erixx haxx wrote:... Then under options panel>> keyboard shortcuts is wrong
I just tried in XnView 0.81 and 0.84 and in both version it says "Ctrl+T" for cmd_tag in "Shortcuts" panel.
Assigning "Space" instead of Ctrl+T in Viewer also worked without problems.
Could you please check, Erixx haxx?
Erixx haxx
Hi:
Yes, this seems fixed.
I think it was a mix up between classic and MP. Both are the same now.
Erixx haxx wrote:Hi:
Good, thank you for your feedback.
:arrow: Closed
