0.81: Video: Pause And UnPause Starts Video Over
Erixx haxx
Hello:
When you pause and then Un-Pause a video it starts the video back to the begining.
Tested Ver:
-v0.79 --Works fine
-v0.81 --Bad
-v0.82-B3 --Bad
Thanks
win7x64pro
Tested Ver:
-v0.79 --Works fine
-v0.81 --Bad
-v0.82-B3 --Bad
Thanks
win7x64pro
Erixx haxx
Re: Video: Pause And UnPause Starts Video Over
Hello
More info here.
When videomode is set to VideoMode=TRUE . The pause\un-pause Works as expected.
So it's a glitch in the other mode.
More info here.
In v0.84 the Pause key is assigned to "Quick slide show" by default. With VideoMode=false it does nothing on my system except toggling "Quick slide show" on and off, which is correct, I think.
Could you please check, Erixx haxx?
Erixx haxx
Hi:helmut wrote:In v0.84 the Pause key is assigned to "Quick slide show" by default. With VideoMode=false it does nothing on my system except toggling "Quick slide show" on and off, which is correct, I think.
I've tried and tried with 0.84 set to videomode=false and can not get it to play videos anymore. So i can't test this anymore.
I've tried with ffmpeg in addons folder also. Thumbs work, but no video.
With autoplay set, then the preview panel plays. So maybe another bug with play button
To be more clear, above I was talking about the Play/Pause button only, and inside full-screen.
I would have been surprised if you could still reproduce your problem: With VideoMode=false (default) there is a problem in v0.84 that keeps the user from restarting a stopped video. See 0.84: Video play, pause and don't start again. Let's see whether v0.85 solves both that and this problem. Would be good if you joined the beta test and retested this bug.Erixx haxx wrote:... I've tried and tried with 0.84 set to videomode=false and can not get it to play videos anymore. So i can't test this anymore. ...
Re: 0.81: Video: Pause And UnPause Starts Video Over
@Erixx Haxx: Could you please check with 0.85 beta 1 (once you are back in town)?
Erixx haxx
Hello:
Thanks.
Yes, I haven't forgotten you. I have a new question in General section that needs answer first.helmut wrote:@Erixx Haxx: Could you please check with 0.85 beta 1 (once you are back in town)?
Thanks.
Works fine for me in 0.85 beta 2. Does this work properly for you too, Erixx Haxx?
Erixx haxx
Confirmedhelmut wrote:Works fine for me in 0.85 beta 2. Does this work properly for you too, Erixx Haxx?
Avi's and some mp4's are wacky, But the pause/ un-pause works.
Good, thank you, Erixx Haxx.Erixx haxx wrote:Confirmedhelmut wrote:Works fine for me in 0.85 beta 2. Does this work properly for you too, Erixx Haxx?
Avi's and some mp4's are wacky, But the pause/ un-pause works.[/quote]I guess a problem of QT AV.
