Broken multipage convert?
flatleyld
Re: Broken multipage convert?
Something must be up with my install then. I've tried the same settings as you and it still fails. I'll try to uninstall and reinstall or try a portable version.
flatleyld
I've been testing some more and found that if I change the "When output files already exist" value to rename instead of replace, the conversion works on all pages. That's not good because I need to replace files in a whole lot of directories, not make duplicates of them.
At a quick look, hopefully not too quick, I don't have a problem with 'Replace' either:flatleyld wrote:I've been testing some more and found that if I change the "When output files already exist" value to rename instead of replace, the conversion works on all pages. That's not good because I need to replace files in a whole lot of directories, not make duplicates of them.
The resulting multipage TIFF opens and views normally...
flatleyld
I'm trying to start from scratch, but XnConvert is storing settings somewhere. Every version I try is holding all of the settings I previously. How do I clear that out and start fresh? I've checked the registry and found nothing.
flatleyld
I've tried this on another computer with the same results.
Do you have the problem even with a simple 'Rotate' action, which is how I'm testing?
I can only suggest that you upload screenshots of your tabs, at least the Input, Output, Status and Settings tabs, although I don't have any ideas about what might be causing the problem.
flatleyld
Yes, I get the same error on a rotate. If I get some time I'll upload screenshots, but they're no different than what I've described.
It's posted above...xnview wrote:please send me your multipage tiff?
where???cday wrote:It's posted above...xnview wrote:please send me your multipage tiff?
Herexnview wrote:where???cday wrote:It's posted above...xnview wrote:please send me your multipage tiff?
Yes, it's along thread now...
houps, thankscday wrote: Yes, it's along thread now...
so no problem here too.
flatleyld
I wonder what the crap is wrong with my install then? Is there a way to clear out all settings and existence of xnconvert and try again?
I don't see it as a problem with your install, although I might be wrong, and in any case you reported the same result on another computer, rather as resulting from a setting you're using, although it is hard to think what could cause the results you are seeing.flatleyld wrote:I wonder what the crap is wrong with my install then? Is there a way to clear out all settings and existence of xnconvert and try again?
I would again suggest uploading screenshots of your tabs mentioned above...
