Out of memory when recursive viewing 20.000+ videos
Moderators: XnTriq, xnview
Moderator & Librarian
Re: Out of memory when recursive viewing 20.000+ videos
Post by XnTriq » Fri Jan 20, 2017 10:00 pm
jadO wrote:
xnview wrote:it's only for create catalog in settings
I don't understand what you are trying to say.
I had been wondering if the fixed leaks were also causing the OOM issues reported by you, jadO.
Thanks for clarifying, Pierre.
Post by xnview » Mon Jan 23, 2017 8:23 am
jadO wrote:I don't understand what you are trying to say.
The problem fixed is when you 'add folder' in catalog setting
jadO
Post by jadO » Mon Nov 27, 2017 10:11 am
This seems to be still an issue. It seems that memory consumption is growing more slowly now, but still it keeps growing and growing and growing.
Edit: It is now using appr. 1GB. But stays at that for some time now. Has that issue been fixed?
Edit 2: It remained at about 1GB for a while but started to grow again after some time causing XnviewMP to crash.
jadO
Post by jadO » Thu Nov 30, 2017 7:32 am
Still memory leaking.
Post by xnview » Thu Nov 30, 2017 8:40 am
jadO wrote:Still memory leaking.
how do you have this memory leak? do you use internal codec or ffmpeg?
jadO
Post by jadO » Thu Nov 30, 2017 11:26 am
Ffmpeg.
Post by xnview » Thu Nov 30, 2017 2:06 pm
Ffmpeg.
but which function do you use?
jadO
Post by jadO » Thu Nov 30, 2017 8:12 pm
xnview wrote:
jadO wrote:
xnview wrote: how do you have this memory leak? do you use internal codec or ffmpeg?
Ffmpeg.
Browser view with setting thumbnailing for entire folder.
jadO
Post by jadO » Sun Dec 03, 2017 10:54 am
Just in case you don't remember: The problem is, that XnviewMP tries to load every file into memory to create thumbnails.
This attempt must fail as XnviewMP has no idea how many files exist and keeps loading and loading until it runs of memory and crashes.
When I use browser view and scroll through the files, XnviewMP creates thumbnails one after another without running out of memory.
So to create thumbnails for whole folder, XnviewMP has to simulate that process: Load files into memory but release them after thumbnail has been created to load new files.
Edit: In fact thumbnailing should be a lightweight background process.
jadO
Post by jadO » Thu Dec 14, 2017 4:37 pm
jadO wrote:Just in case you don't remember: The problem is, that XnviewMP tries to load every file into memory to create thumbnails.
Any news on this?
Post by xnview » Mon Dec 18, 2017 4:47 pm
It's not a memory leak like previous problem, only that all thumbnails take all memory because currently they are ALL in memory...
jadO
Post by jadO » Tue Dec 26, 2017 2:01 pm
xnview wrote:It's not a memory leak like previous problem, only that all thumbnails take all memory because currently they are ALL in memory...
So it is a memory leak by design? How can this be changed? I mean first of all I don't see any sense in loading all files/thumbnails into memore. This MUST result in memory issues. Also a good design for thumbnailing whole folder would be a background process with low cpu and memory footprint so that XnviewMP still can be used at the same time.
