I'm not sure I'm using XnViewMP or Classic. The 'About' dialog in the help menu just says 'XnView for Windows'. (You'd think if it is important, then it would be mentioned in this dialog.)
Anyway, the program keeps showing a message "Please purchase CAD Image DLL to remove this text..." when cycling through a folder full of images and it comes across an SVG image.
I do not plan on purchasing this plugin. How do I tell XnView to skip and ignore SVG images? Thanks.
Ignore SVG images
- Moderator & Librarian
Re: Ignore SVG images
You're using XnView Classic. Please add SVG to the exclusion list for Custom files (*) alongside…
… in Tools » Options... » File List » File List.
HTM HTML MHT MHTML XML XHTML EML NWS URL
In what sense is that an exclusion list? It says "Choose which items are shown in the browser", so it seems like an inclusion list.XnTriq wrote: ↑Wed Nov 09, 2016 3:45 am You're using XnView Classic. Please add SVG to the exclusion list for Custom files (*) alongside…
… in Tools » Options... » File List » File List.Code: Select all
Here's a better method: Just delete the file CADImage.dll from
C:\Program Files (x86)\XnView\PlugIns
- Moderator
In the file list you can specifiy whether items are shown or hidden. So in these settings you can both include and exclude file types.
Right, that's also an option. Just note that after removing DLL you will no longer be able to view SVG files in XnView at all - neither in XnView browser as thumbnails nor in XnView's image view.
