No switching between panels using keyboard (Tab)
Re: No switching between panels using keyboard (Tab)
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
Good to see this implemented in XnView 1.4.0. With F6 function key you can switch between panels.
For switching between panels the typical shortcut is "Ctrl + Tab" for switching panels forward and "Ctrl + Shift + Tab" for switching panels backwards - these shortcut works in FireFox or Google Chrome, for example. So I'd suggest to change shortcut F6 to "Ctrl + Tab" and to add "Ctrl + Shift + Tab" for switching between panels backwards.
ckit
+1helmut wrote: Thu Dec 29, 2022 1:13 pm Good to see this implemented in XnView 1.4.0. With F6 function key you can switch between panels.
diusonem
perfect! took a while to find this!
