XnView MP 0.84
Moderators: XnTriq, xnview
XnView MP 0.84
Postby xnview » Mon Jan 16, 2017 3:46 pm
Please, don't post bugs or request in this topic!
You can download XnView MP 0.84 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
    SHA256: 6E76C845A8A6E1C573AE742B81A3390734DA6F794465EAB2787B9FD105CBCEC2
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
    SHA256: 27039865D127713E7181A5F307C8B74393AAF0CBE6B5F2662FBB7A869E488700
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Linux x64 AppImage: http://download.xnview.com/XnViewMP.gli ... 4.AppImage
Changelog 0.84:
1050: [Bugs] Image saved ot updated in browser - viewtopic.php?f=62&t=34543
1046: [Bugs] UTF8 in .XnViewSort - viewtopic.php?f=62&t=34484
1045: [Bugs] Crash with .001 files - viewtopic.php?f=62&t=34406
1044: [Bugs] Wheel mouse in browser - viewtopic.php?f=62&t=34242
1037: [Bugs] VideoMode=true - viewtopic.php?f=62&t=33599
1038: [Bugs] Slow delete when many subfolders exist - viewtopic.php?f=62&t=34327
1033: [Bugs] Leaks when creating catalog - viewtopic.php?f=82&t=34220
1032: [Bugs] Some problems with IPTC-XMP dialog - viewtopic.php?f=83&t=34053
1031: [Bugs] Set Rating/category & batch rename - viewtopic.php?f=62&t=34110
1030: [Bugs] Move subfolder in same path - viewtopic.php?f=82&t=34146
1029: [Bugs] Crash when setting a category and enter something in quicksearch
1028: [Bugs] Crash at start with win10 build 14965 - viewtopic.php?f=62&t=34135
1027: [Bugs] 180° rotation on BW picture
1026: [Bugs] 8bf 64bits plugin - viewtopic.php?f=82&t=34174
1024: [Bugs] -ini & startup wizard - viewtopic.php?f=82&t=33874
1023: [Requests] Mosaic effect missing - viewtopic.php?f=82&t=34196
1022: [Requests] Paint feature
1017: [Bugs] Delta Y in Watermark - viewtopic.php?f=79&t=34101
1016: [Bugs] 'sort' numeric not default - viewtopic.php?f=82&t=34064
1013: [Bugs] 'save as' extension - viewtopic.php?f=62&t=34019
1012: [Bugs] 'Save as' doesn't use 'keep date' - viewtopic.php?f=62&t=34019
1009: [Bugs] Custom path empty - viewtopic.php?f=82&t=33976
1008: [Bugs] Freeze when viewing folder of icon files - viewtopic.php?f=62&t=33964
0642: [Bugs] View problem - viewtopic.php?f=62&t=31581
0491: [Bugs] View problem - viewtopic.php?f=62&t=30721
1007: [Bugs] XnView freeze when closing view of RAW - viewtopic.php?f=62&t=33966
0978: [Bugs] MacOSX - edit description crash
1005: [Bugs] Slow start & .XnViewSort - viewtopic.php?f=62&t=33609
1004: [Requests] afdesign thumbnail - viewtopic.php?f=82&t=33948
1003: [Requests] Qt 5.6.2
1002: [Bugs] Problem category rename/move - viewtopic.php?f=62&t=33628
1001: [Bugs] Sessions & one instance - viewtopic.php?f=62&t=33607
0998: [Bugs] IPTC edit & parent keywords - viewtopic.php?f=83&t=33887
0993: [Bugs] Flickr removed - viewtopic.php?f=62&t=32077
0989: [Requests] XnView after filename in titlebar - viewtopic.php?f=60&t=33762
0955: [Requests] Check for update - viewtopic.php?f=60&t=33710
0975: [Bugs] Import with custom filename - viewtopic.php?f=83&t=33830
0992: [Requests] No session saved if tabs not used - viewtopic.php?f=62&t=33928
0991: [Bugs] Import&sort video files not copied - viewtopic.php?f=36&t=33907
0985: [Bugs] FLIF output failed - viewtopic.php?f=62&t=33897
0988: [Bugs] Catalog 'Delete' and 'Delete all' don't have same behavior - viewtopic.php?f=82&t=33865
0986: [Bugs] Going back to browser doesn't select the good file - viewtopic.php?f=62&t=33807
0984: [Bugs] BPG console flicker - viewtopic.php?f=62&t=33861
0983: [Bugs] File format color not working - viewtopic.php?f=62&t=33870
0982: [Requests] FLIF 0.2
0981: [Bugs] Sidecar naming - viewtopic.php?f=82&t=33390
0980: [Bugs] '/' used in copy clipboard - viewtopic.php?f=62&t=33833
0979: [Bugs] Export dialog and resampler method - viewtopic.php?f=62&t=33867
0977: [Bugs] Parameter for external editor - viewtopic.php?f=62&t=33842
0976: [Bugs] Export output folder - viewtopic.php?f=62&t=29769&p=134635
Changelog 0.83:
972: [Requests] Naming of sidecar - viewtopic.php?f=82&t=33390
971: [Bugs] Can't open PDF files on network drive - viewtopic.php?f=35&t=33814
970: [Bugs] Linux: Moving create bad modified date - viewtopic.php?f=62&t=33784
968: [Bugs] Some shortcuts don't work on MacOSX - viewtopic.php?f=62&t=33786
969: [Bugs] OpenEXR on Linux - viewtopic.php?f=62&t=33800
967: [Bugs] Video playback hangs - viewtopic.php?f=62&t=33763
965: [Bugs] MacOSX Quits after displaying warning dialog - viewtopic.php?f=62&t=33769
Changelog 0.82:
947: [Bugs] Video files no imported - viewtopic.php?f=83&t=33629 [^] - resolved.
944: [Bugs] Scroll wheel and thumbstrip selection in fullscreen - viewtopic.php?f=62&t=33533 [^] - resolved.
943: [Requests] Edit GPS - resolved.
942: [Bugs] Ctrl+X crash on many files - resolved.
941: [Bugs] space at start/end when renaming - viewtopic.php?f=62&t=33644 [^] - resolved.
939: [Bugs] XnView can't start if file doesn't exists anymore - viewtopic.php?f=62&t=33576 [^] - resolved.
936: [Bugs] Show grid - viewtopic.php?f=62&t=33441 [^] - resolved.
934: [Bugs] Annotation not shown on folder, thumbnails labels - viewtopic.php?f=62&t=33597 [^] - resolved.
930: [Bugs] .keys coding - viewtopic.php?f=84&t=33603 [^] - resolved.
929: [Requests] EXIF GPS direction - viewtopic.php?f=35&t=33587 [^] - resolved.
928: [Bugs] Video & double click - viewtopic.php?f=82&t=33577 [^] - resolved.
908: [Requests] WebP 0.5.1 - viewtopic.php?f=60&t=33399 [^] - resolved.
926: [Bugs] Browser fullscreen - ESC doesn't work - resolved.
925: [Requests] affinity photo format - viewtopic.php?f=82&t=33496&start=15 [^] - resolved.
924: [Bugs] Export disabled - viewtopic.php?f=62&t=33503 [^] - resolved.
922: [Bugs] Change date/time & DST - resolved.
919: [Bugs] __CMD__ doesn't work sometimes - viewtopic.php?f=62&t=33474 [^] - resolved.
918: [Bugs] Lossless rotate, rotate by edit exif orientation - viewtopic.php?f=62&t=33433 [^] - resolved.
912: [Bugs] Batch Convert: Place holder & Clean Metadata action - viewtopic.php?f=79&t=33429 [^] - resolved.
911: [Bugs] Rating menu always available - viewtopic.php?f=62&t=33400 [^] - resolved.
910: [Bugs] Filter by rating/label after changing rating/label crash (property view) - resolved.
909: [Requests] Auto image size setting - viewtopic.php?f=60&t=33389 [^] - resolved.
907: [Bugs] Set comment after capture - resolved.
905: [Bugs] Show tagged files & base path - resolved.
904: [Bugs] Sidecar not readed if filename.ext.xmp - viewtopic.php?f=82&t=33381 [^] - resolved.
903: [Bugs] SVG not supported - viewtopic.php?f=62&t=33371 [^] - resolved.
779: [Bugs] Fullscreen switching - viewtopic.php?f=62&t=32610 [^] - resolved.
608: [Bugs] Browser fullscreen setting - viewtopic.php?f=82&t=30577&start=15 [^] - resolved.
181: [Bugs] Crop&move - viewtopic.php?f=62&t=27377 [^] - resolved.
827: [Requests] Better update dialog - viewtopic.php?f=34&t=19950 [^] - resolved.
790: [Bugs] Move & original date - viewtopic.php?f=62&t=32684 [^] - resolved.
786: [Bugs] Crash on gif view - viewtopic.php?f=82&t=32652 [^] - resolved.
780: [Bugs] Custom sort - viewtopic.php?f=62&t=32609 [^] - resolved.
775: [Bugs] Scrollbar override - viewtopic.php?f=62&t=32586 [^] - resolved.
629: [Bugs] Print caption & pictures collection - viewtopic.php?f=82&t=31456 [^] - resolved.
698: [Bugs] Quick Search UI - viewtopic.php?f=79&t=32129 [^] - resolved.
663: [Bugs] EXIF rotation - viewtopic.php?f=62&t=23933 [^] - resolved.
623: [Bugs] Search & base path - viewtopic.php?f=62&t=31366 [^] - resolved.
578: [Bugs] ESC to close fullscreen - viewtopic.php?f=62&t=31198 [^] - resolved.
879: [Bugs] Copy instead of Move action - viewtopic.php?f=62&t=33327 [^] - resolved.
900: [Bugs] Batch convert, resize in cm/mm - resolved.
899: [Bugs] Switch browser-> Fullscreen & titlebar - resolved.
898: [Requests] Open all in context menu - resolved.
896: [Bugs] Refresh doesn't work - viewtopic.php?f=62&t=33358 [^] - resolved.
894: [Bugs] Custom _cmd_ not working in view mode - resolved.
893: [Bugs] Exif orientation & rotate 180 - viewtopic.php?f=62&t=33325 [^] - resolved.
892: [Bugs] If sidecar is empty, do not read IPTC - viewtopic.php?f=62&t=33252 [^] - resolved.
891: [Bugs] Always play video - viewtopic.php?f=62&t=33337 [^] - resolved.
889: [Requests] LockZoomFlag to not keep LockZoom - viewtopic.php?f=82&t=33326 [^] - resolved.
888: [Bugs] EXIF lost after rotation - viewtopic.php?f=62&t=33344 [^] - resolved.
887: [Bugs] Catalog off & show thumbnail for folder off - resolved.
Changelog 0.81:
883: [Bugs] GPS map issues - viewtopic.php?f=62&t=33341
882: [Requests] QT 5.6.1
881: [Bugs] Delete in view mode doesn't work - viewtopic.php?f=62&t=33324
880: [Bugs] Thumbnail size change thumbnails view - viewtopic.php?f=62&t=33254
756: [Bugs] Print custom size - viewtopic.php?f=62&t=32327
877: [Bugs] Thumbnail mode & thumbnail size menu - viewtopic.php?f=62&t=33253
875: [Bugs] Export after join/Capture - viewtopic.php?f=62&t=33275&p=132575
Changelog 0.80:
871: [Requests] Libjpeg-turbo 1.5.0
870: [Bugs] Copy/Move file lose categories with base path
869: [Bugs] Copy/move dialog size - viewtopic.php?f=82&t=33285
867: [Requests] Convert, Hot folders recursive flag
866: [Bugs] B&W picture rotation crash
863: [Bugs] Estimated jpeg quality not used for writing
864: [Requests] MacRoman as iptc encoding
858: [Bugs] Filter list ignored in view mode - viewtopic.php?f=62&t=32534&p=132139
855: [Bugs] Optimize catalog & base path - viewtopic.php?f=62&t=33174
854: [Bugs] File copy not added at the end - viewtopic.php?f=62&t=33108&p=132081
853: [Requests] QT 5.6.0
762: [Bugs] Drag&Drop toolbar item remove it - viewtopic.php?f=62&t=32451
852: [Bugs] Ctrl+X not working after 1st start - viewtopic.php?f=62&t=33095
850: [Bugs] Open an image from windows explorer is slow
849: [Bugs] Fullscreen on second monitor - viewtopic.php?f=82&t=33071
848: [Bugs] Rename/delete can crash or use another file - viewtopic.php?f=82&t=33003
826: [Bugs] Batch rename must use tmp-xnview-ORGFILENAME-#### instead tmp-xnview-####
846: [Bugs] Can't delete folder - viewtopic.php?f=62&t=32989
843: [Bugs] Custom toolbar buttons - viewtopic.php?f=62&t=33021
841: [Requests] Address bar width - viewtopic.php?f=82&t=33008
839: [Bugs] Bad icon for EXE - viewtopic.php?f=62&t=33009
834: [Bugs] 4thumbs video and ffmpeg
831: [Bugs] Import&sort doesn't work - viewtopic.php?f=82&t=32973
680: [Requests] Red eye removal - viewtopic.php?f=82&t=31997&p=127190
830: [Bugs] XMP leak - viewtopic.php?f=62&t=32943
842: [Bugs] Session not restored if open with 1 file - viewtopic.php?f=82&t=32589&p=131504
Re: XnView MP 0.84
Postby helmut » Mon Jan 16, 2017 4:09 pm
Thank you for the new version 0.84 of XnView MP, Pierre. All the above download links are broken; could you please check?
Re: XnView MP 0.84
Postby xnview » Mon Jan 16, 2017 4:15 pm
helmut wrote:Thank you for the new version 0.84 of XnView MP, Pierre. All the above download links are broken; could you please check?
fixed
Re: XnView MP 0.84
Postby helmut » Mon Jan 16, 2017 4:49 pm
fixed
Good, thank you.
Moderator & Librarian
Re: XnView MP 0.84
Postby XnTriq » Tue Jan 17, 2017 12:45 am
Thanks, Pierre!
Please update update.txt :mrgreen:
rinthe
Re: XnView MP 0.84
Postby rinthe » Wed Jan 18, 2017 9:15 pm
awesome!
Re: XnView MP 0.84
Postby XnTriq » Thu Jan 19, 2017 7:45 pm
The version has to be updated on the website.
  • http://www.xnview.com/en/
  • http://www.xnview.com/en/xnviewmp/
  • http://www.xnview.com/fr/
  • http://www.xnview.com/fr/xnviewmp/
  • http://www.xnview.com/de/
  • http://www.xnview.com/de/xnviewmp/
Re: XnView MP 0.84
Postby xnview » Fri Jan 20, 2017 9:10 am
XnTriq wrote:The version has to be updated on the website.
fixed
M-B
Re: XnView MP 0.84
Postby M-B » Fri Jan 20, 2017 11:13 am
...finally a thumbnail preview for all Affinity-Files - Thank You very much!! : )
Return to “MP - General Support”
Who is online
Users browsing this forum: No registered users and 1 guest
