There are a wide range of resolutions and screen sizes on which XnView MP works. Some complain that the text is too small (usually) for others the text is ok and some think that the text is a little too big.
It is easy to add an option in Tools | Settings | Interface with a Spin Edit saying "Font Size:" and put there the actual font size. A simple call to QFont.SetPointSize will make happy everyone. Make sure that you will persist the value tough.
Now there are people which copy/paste metadata in Word, edit and copy/paste it back just because they don't see clearly the text.
Provide the possibility to change the Font Size
m.Th.
m. Th.
Re: Provide the possibility to change the Font Size
+1 Ability to change the overall fontsize would be very useful. Depending on the effort needed this should be implemented, soon.
