0.84: Always "Folder" after hiding data pane
XnView: MP 0.84
OS: Windows 10 - 64bit
When hiding and showing the data pane, again, always "Folder" is chosen.
Effect: Unexpected user interface
1. Open XnView browser
2. Select "Categories Filter" in the data pane.
3. Hide the Data pane
4. Show the data pane, again.
Actual behaviour (bug): Data pane is displayed and "Folder" is shown :bug:
Expected behaviour: Data pane is displayed and the previous "Categories Filter" tab is shown.
XnTriq wrote:Note: Adding a button for cmd_treeShow is the fastest way to reproduce this bug.
Re: 0.84: Always "Folder" after hiding data pane
yes but i have no way to know which docked panel is active
xnview wrote:yes but i have no way to know which docked panel is active
Isn't there any event triggered when a tab gets visible?
i found a way
i found a way
Good. :)
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Confirmed fixed in 0.85 beta 1.
